(PR) CORSAIR today announced the immediate availability of its VENGEANCE RGB DDR5 CUDIMM memory kits, delivering capacities of up to 96GB and initial frequencies reaching 9,200 MT/s, with even faster kits arriving soon. These CUDIMMs are optimized for the latest Intel Core Ultra 200-series processors and Z890 motherboards, while also offering backward compatibility with previous DDR5 platforms.
CUDIMM stands for Clocked Unbuffered Dual In-line Memory Module, a technology developed specifically for high-performance computing with support for higher frequencies than standard UDIMMs. Built on the same DDR5 architecture as traditional UDIMMs, CUDIMMs include a Clock Driver IC (CKD) to improve clock signal stability and synchronization by regenerating and amplifying the clock signal, ensuring each chip on the memory module receives precise timing information. CUDIMMs can achieve transfer rates exceeding 9,000 MT/s.
CORSAIR CUDIMMs are compatible with existing DDR5 architectures and platforms when used in Bypass mode, operating like traditional UDIMMs. To unlock the full potential of CUDIMMs, a compatible platform, such as Intel’s latest Core Ultra 200-series CPUs and Z890 motherboard, is required. This setup supports the improved signal integrity for reliable performance, making VENGEANCE RGB DDR5 CUDIMMs the ideal choice for enthusiasts and professionals seeking extreme performance.
The CORSAIR lineup of CUDIMM memory kits begins with the release of the VENGEANCE RGB DDR5 CUDIMM, available today, with the non-RGB versions shipping shortly after in the first week of December. Initial kits include 48GB and 96GB capacities with speeds ranging from DDR5-8400 up to DDR5-9200. Memory frequencies and timings are stored using Intel XMP 3.0 performance profiles, making it easy to achieve optimal performance with a quick trip to the BIOS to enable your chosen profile.
CORSAIR VENGEANCE RGB DDR5 CUDIMMs stand out from previous VENGEANCE DDR5 offerings with a sleek mirrored silver finish, adding a refined aesthetic to any build. Ten individually addressable RGB LEDs illuminate your build with customizable lighting effects, enhanced by a panoramic light bar that extends to the module’s edges, providing vibrant RGB lighting from nearly any viewing angle. In addition to dynamic RGB customization and synchronization across your setup, iCUE Software serves as a complete DDR5 command center, enabling real-time frequency monitoring and onboard voltage regulation within a single, coherent interface.
As with all CORSAIR DDR5 memory, CORSAIR VENGEANCE DDR5 CUDIMMs are built using hand-sorted, tightly screened memory chips to ensure consistently high frequencies, mounted on high-performance PCBs for superior signal quality and stability. Cooling is provided by a sleek heatspreader that efficiently dissipates heat while enhancing your system’s modern aesthetic. A limited lifetime warranty offers peace of mind that your new memory will last throughout your PC’s lifespan and future upgrades.
Availability, Warranty and Pricing
CORSAIR VENGEANCE RGB DDR5 CUDIMM kits are available immediately from the CORSAIR webstore and the CORSAIR worldwide network of authorized retailers and distributors.
CORSAIR VENGEANCE RGB DDR5 CUDIMMs are backed by a limited lifetime warranty, alongside the CORSAIR worldwide customer service and technical support network.
