(PR) ASUS today announced the ProArt PA401 Wood Edition chassis, a smaller variant of theĀ ProArt PA602 Wood EditionĀ that can fit high-performance PC components, keep them cool under load, and look stylish while doing so. For those who want a thermally optimized case with visual luster and all the home and lifestyle-focused essentials they could ask for in a more space-saving form factor, the PA401 delivers.
The ProArt PA401 Wood Edition is an aesthetic charmer that is perfect for lifestyle users in need of a distinct, tasteful PC case featuring strong thermal performance on top of some useful bells and whistles. Between its side panel options, impressive cooling capabilities and multitude of PC-building conveniences, it is the go-to case option for those looking to dabble in the desktop space for the very first time. Whether using it in a studio or a home office, it will blend in with its environment and leave ample space for other hardware and accessories.
Subtlety and sophistication
The ProArt PA401 Wood Edition integrates wood into its front panel for a truly distinctive look. This durable ash wood is certified by the Forest Stewardship Council for sustainability, meaning users can rest easy knowing their caseās unique aesthetic is made with the environment in mind.
The wood for this panel goes through a six-stage process, including a thermowood treatment that shapes and refines each piece to perfection. Then there is a two-step coating process that highlights the natural appearance of the grain while also applying a low-sheen finish. This produces a front panel that is artistically inspired, professional and minimalist.
Furthermore, there are two choices for the PA401 side panel so that users can best tailor the chassis to their sensibilities. Users can opt for a metal side panel to maximize case durability and score a sleek black finish, or go with a tempered glass panel that will show off a PCās internal components.
Cool casing and convenient controls for the hottest workloads
Everyday users need a low-noise, airflow-optimized chassis so they can focus on their work and not be distracted by their PC. This is where the PA401 excels. The caseās cooling power starts with its open-grille front panel, which provides unimpeded air intake for the dual 160 x 32mm intake fans. Those unique ring fan blades deliver up to 138cfm of airflow. Larger volumes of air keep components cool without excess noise, ensuring a machine remains at healthy temperatures regardless of how demanding a workflow gets. The preinstalled 120mm rear fan exhausts heat for an effective cooling loop.
To provide maximum control, the caseās front panel features an integrated PWM control so users can switch their PCās fan mode with a single input. This utility is perfect for when users are alternating between low-level tasks like web browsing and high-intensity workflows that leverage demanding programs and require maximum PC cooling power.
Builder-friendly features make assembly easy
The ProArt PA401 Wood Edition is an ATX mid-tower case that provides a multitude of features to make building a dream machine a breeze. With the PA401, part installations, cable management and other functions are simpler than ever.
Getting inside the chassis is easy with the tool-free design of the PA401. Side panels release with a simple button press, giving instant access to a PCās internal components. Balancing ease of access with hardware security, a left-side panel lock is included.
The rear bracket detaches from the case so users can install a power supply by simply sliding it into place. Tool-free 3.5-inch HDD installation simplifies the assembly process, letting users insert a new drive with their bare hands when they want to upgrade their PC’s storage capacity.
Rear cable clips help keep wiring orderly, safe and aesthetically pleasing. Plus, the PA401 offers two ways to orient a graphics cardāvertically or horizontally, depending on a userās setup and preferences.
Quality-of-life features
The ProArt PA401 Wood Edition chassis does more than simplify the building process; it adds extras that can genuinely improve day-to-day PC usage.
To accommodate peripherals, the front panel is stocked with USB ports, including a lightning-fast USB 20Gbps Type-C port. Users can simply couple the PA401 with aĀ compatible motherboardĀ to take advantage of it. Two additional USB 3.0 Type-A ports provide more ways to connect devices and gadgets.
For users who may be concerned about mistakenly tapping the nearby power button while using those front ports, there is a physical lock latch to prevent mishaps. Flip the lock on, and it will ensure that the power and reset buttons cannot be pressed.
To keep components free of dust, there are removeable dust filters in the front and bottom of the case. No matter how much air flows in and out of this chassis, dust will not be a problem.
For users who want a case with even more connectivity options and extra internal space for large PC components, be sure to check out theĀ ProArt PA602 Wood Edition, which offers the striking aesthetics and handy features of the PA401 while including a few more features, thanks to its bigger size.
Gallery
Specifications
Motherboard Compatibility | ATX, microATX, Mini-ITX |
Dimensions | 412 x 225 x 503mm |
Materials | Steel, ABS plastic, wood Tempered glass (Tempered Glass SKU only) |
I/O Ports | 2 x USB 5Gbps (Type-A) 1 x USB 20Gbps (Type-C) 1 x headphone + microphone |
3.5″/2.5″ Drive Bays | 2 |
Expansion Slots | 7 |
Vertical Expansion Slots | 2 |
Maximum GPU Length | 315mm |
Maximum CPU Cooler Height | 160mm |
Maximum PSU Length | 170mm |
Radiator Compatibility | Top: 120/140/240mm |
Cooling Support | Front: 2 x 160mm / 2 x 140mm Top: 2 x 140mm / 2 x 120mm Rear: 1 x 120mm |
Pre-Installed Fans | Front: 2 x 160mm PWM Rear: 1 x 120mm PWM |
Removable Dust Filters | Front + bottom |
Cable Routing | 34mm |
Extension Hub | Supports PWM fan output x 5 |
Weight | 8.61 kg (Tempered Glass version), 7.94 kg (Metal Panel version) |
