ACER has seemingly confirmed NVIDIA GeForce RTX 5090 32 GB and RTX 5080 16 GB memory sizes via a leaked datasheet. With only two weeks to go until CES 2025, when NVIDIA CEO Jensen Huang is expected to officially unveil the new RTX 50 series, it appears one needn’t look for rumors from hardware insiders since it seems easier to obtain promotional materials and content from manufacturers instead. The latest comes via datasheets for ACER’s Predator Orion 7000 series pre-built gaming PCs which appear to be getting updated with the unreleased GPUs.
According to the datasheet, ACER is planning two models, one with an NVIDIA GeForce RTX 5090 32 GB graphics card (a VRAM configuration recently listed Zotac as well) and then an alternate with an NVIDIA GeForce RTX 5080 featuring 16 GB of GDDR7 memory. Both models also include an Intel Core Ultra 7 265KF processor, something many gamers are likely to wonder about, paired with 32 GB DDR5-6000 of system memory. The leaked datasheet comes via VideoCardz who somehow managed to obtain it.
The NVIDIA GeForce RTX 5080 graphics card is rumored to use a GB203 die with 10,752 CUDA cores. It has also been rumored that it may launch with two variants, one with 16 GB, and another with 24 GB of GDDR7 memory, both on a 256-bit bus. Another new rumor states that its memory modules will be running 30 Gbps providing 960 GB/s of bandwidth. Its TDP might be 400 Watts.
The NVIDIA GeForce RTX 5090 graphics card is rumored to use a GB202 die with 21,760 CUDA cores. While 32 GB of VRAM seems all but official it is still not known if this will be on a 384-bit (similar to past x90 models) or on a 512-bit bus (something rarely seen on consumer graphics cards) that could have a bandwidth of over 1.7 TB/s. The power draw for the unannounced card is believed to be around 600 Watts.
