SAPPHIRE NITRO+ Radeon RX 9070 XT Video Card Review
Power and Temperature
Power
 SAPPHIRE Nitro+ Radeon RX 9070 XT Gaming OC:  power draw
Above, we see that by default, the SAPPHIRE NITRO+ Radeon RX 9070 XT uses the highest amount of power for the default benchmark run-through compared to the other cards. We see anywhere from 5 to 14% more power utilized. It also runs right at the TBP listed at 330W. When overclocked and pushing the power limit to +10%, the card uses every bit it can; in fact, pushing to some pretty high power usage for very little performance gain.
Temperature
 SAPPHIRE Nitro+ Radeon RX 9070 XT Gaming OC: temperature
In HWInfo64, our card shows the same maximum temperature whether at default or overclocked. The fans were left on the default curve, so all the card does is spin up the fans from 34% to 41% to manage the heat increases in overclock. That’s pretty good right there and says a lot about the heatsink for this video card, SAPPHIRE did a great job with the cooling on the SAPPHIRE NITRO+ Radeon RX 9070 XT; it works well.
Gaming Performance
Overclocking
Build Quality and Cooling
Todays review is evaluating the SAPPHIRE NITRO+ Radeon RX 9070 XT Gaming OC video card. This brand new RDNA 4 card from SAPPHIRE is a premium quality video card. The gaming performance matches the NVIDIA GeForce RTX 5070 Ti Founders Edition in many plain rasterized games, but falls short in ray tracing performance. The SAPPHIRE NITRO+ Radeon RX 9070 XT performs much better than the previous generation, but again its Achilles heel is ray tracing. Cooling design is excellent. For non-ray traced gaming the price of this card makes it quite a value as does the overall quality of the build. This is a top-tier, all-in build from SAPPHIRE, they knocked it out of the park with this NITRO+ series in the design.
