XFX Swift AMD Radeon RX 9070 XT White Triple Fan Gaming Edition Video Card Review
Power and Temperature
Power
XFX Swift AMD Radeon RX 9070 XT White Triple Fan Gaming Edition: Power use
The quoted specification for power usage by AMD for the 9070 XT is 304 Watts. Here we can see that the XFX Swift AMD Radeon RX 9070 XT White Gaming Edition exceeds that cap in both default and overclocked settings. The default is essentially right at the edge, and overclocked is 12% over. The MSI GeForce RTX 5070 Ti VANGUARD SOC LAUNCH EDITION uses 9% and 18% less power.
Temperature
XFX Swift AMD Radeon RX 9070 XT White Triple Fan Gaming Edition: GPU temperature
Temperatures are quite impressively low on the GPU, a reflection of the excellent cooling setup on both cards. The fan cycle on the overclocked XFX Swift AMD Radeon RX 9070 XT White Gaming Edition was manually set by adjusting the fan curve in Adrenalin. It ran at 62%. By default, it ran at 36% on automatic settings. The MSI GeForce RTX 5070 Ti VANGUARD SOC LAUNCH EDITION is likewise very cool running default settings. Memory temperatures are a bit higher, with the MSI GeForce RTX 5070 Ti VANGUARD SOC LAUNCH EDITION doing quite well, nearly 27% cooler at default settings!
XFX Swift AMD Radeon RX 9070 XT White Triple Fan Gaming Edition:  memory temperature
The function of the heatsinks on both these models of video cards is very good. The GPU cooling on the “good” XFX Swift AMD Radeon RX 9070 XT White Gaming Edition bests the premium edition MSI GeForce RTX 5070 Ti VANGUARD SOC LAUNCH EDITION by 10C. Also, the function of the fans at both default and 60% fan cycle is very quiet. In a closed case, you would not hear fan noise from the video card. All in all, very nice, right there.
The FPS Review Score
9.5
This article reviews the XFX Swift AMD Radeon RX 9070 XT White Triple Fan Gaming Edition video card. This is a very well built card with a simple design appeal. The cooling is excellent and quiet. Gaming performance is quite good in plain Raster, trading blows evenly with the more expensive RTX 5070 Ti. The card is not as successful in ray tracing enabled games. At 1440p gaming this video card would be an excellent choice, and it offers a better value proposition compared to more expensive Radeon RX 9070 XT's, and the more expensive GeForce RTX 5070 Ti, this is simply a better value for 1440p gaming.
