GIGABYTE GeForce RTX 5070 EAGLE OC ICE SFF 12G Video Card Review
Power, Temperature, and Fans
Power
GIGABYTE GeForce RTX 5070 EAGLE OC ICE SFF 12G : Power useage
In this graph, we see that the overclocked GIGABYTE GeForce RTX 5070 EAGLE OC ICE SFF 12G has the highest power usage, but by a modest amount. We can also see that the default GIGABYTE GeForce RTX 5070 EAGLE OC ICE SFF 12G draws well under the specification for total power draw. The higher draw in overclocking is no doubt a result of the generous power limit increase of 20%. This would tend to imply there is more in the tank as far as overclocking goes.
Temperature
These two graphs demonstrate the very excellent cooling of both our video cards in this review. In default performance, the GIGABYTE GeForce RTX 5070 EAGLE OC ICE SFF 12G is a cool 68.5C but even that is eclipsed by the 59C of the XFX QuickSilver AMD Radeon RX 9070 OC Gaming Edition. Both of these cards have been designed with cooling as a priority. Overclocking does boost the temperature slightly, but still only to just above 70C. Memory temperatures are identical for the GIGABYTE GeForce RTX 5070 EAGLE OC ICE SFF 12G, whether overclocked or default. The XFX QuickSilver AMD Radeon RX 9070 OC Gaming Edition runs hotter, but also has more memory chips.
Fan Cycle
GIGABYTE GeForce RTX 5070 EAGLE OC ICE SFF 12G : Fan performance
In this graph, you can see the fan ramp up in response to rising temperatures. The overclocked XFX QuickSilver AMD Radeon RX 9070 OC Gaming Edition requires 50% fans to run at 70.3C while the default card needs only 48% to run at 68.5C. The step-wise increases are nearly mirror images until they reach equilibrium. Even with the fans between 48 and 50% you simply cannot hear them on an open bench.
Gaming Performance
Build Quality and Cooling
Overclocking
9.5
Price and Value
This review evaluates the GIGABYTE GeForce RTX 5070 EAGLE OC ICE SFF 12G. This RTX 5070 is built to conform to NVIDIA Small Form Factor specifications. This criteria is welcome. It reduces problems in building smaller high performance PCs. The overall build and fit and finish is very well done. This review looks at the "ICE" or white video card, also offered in black. Gaming performance is on par with other RTX 5070 video cards but is nicely boosted by overclocking. Whether you are building a SFF PC or a regular sized desktop PC the GIGABYTE GeForce RTX 5070 EAGLE OC ICE SFF 12G is worth your consideration.
