AMD Radeon AI PRO R9700 Featuring 32 GB GDDR6 Gets Wide Release on October 27 for $1,299, PowerColor Reveals 12VHPWR Model
Image: AMD
AMD first revealed the AI PRO R9700 back in July, when, at the time, it was limited to OEM channels, but it will soon be available to the public for purchase. The Radeon AI PRO R9700 is AMD’s first product aimed at professionals using its AMD RDNA 4-based Navi 48 GPU and is paired with 32 GB GDDR6 on a 256-bit bus. Essentially, this card is a slight step up from the AMD RX 9070 XT. Both feature HDMI 2.1b, DisplayPort 2.1a, and support for PCI-Express 5.0. However, the AI PRO R9700 has an MSRP of $1,299 (via product slide obtained by VideoCardz) while the RX 9070XT has an MSRP of $599. Why the comparison, you ask? Well, because there are already discussions occurring online asking if the AI PRO R9700 should be considered a worthy game successor to the RX 9070 XT, which is honestly a bit of an apples-to-oranges comparison since one is intended for professional use while the other is not, but similar discussions do happen regarding NVIDIA’s x90 lineups vs their professional GPU offerings.
Radeon AI Pro R9700 Specifications:
Image: AMD
Radeon RX 9070 XT Specifications:
ImageL AMD
Further specifications comparison:
ModelGPUCoresBoost ClockTMUSROPSMemory SizeMemory TYPEMemory BUSMemory ClockPower DrawMSRP
Radeon AI PRO R9700Navi 4840962920 MHz25612832 GBGDDR6256-bit2518 MHz300W$1,299
Radeon RX 9070 XTNavi 4840962970 MHz25612816 GBGDDR6256-bit2518 MHz304W$599
Meanwhile, it appears that another AMD partner is offering a model with the notorious 12VHPWR connector. PowerColor has revealed that it is offering a variant called the AI PRO R9700 32G-B that uses the 16-pin connector and will include a 2x 8-pin adapter featuring yellow tips to aid in its proper use. There’s no mention of whether PowerColor has included any load-balancing technology on the PCB.
Image: PowerColor
