This review evaluated the LIAN LI LANCOOL 217 Black Genuine Walnut Trimmed combined with the GIGABYTE X870E AERO X3D DARK WOOD Motherboard. We were able to evaluate and assemble a build using the LIAN LI LANCOOL 217 wood-trimmed case. This is a very well-designed mid-ATX case with real walnut accent pieces and is available for $119.
Using the LIAN LI LANCOOL 217
The build-up of the GIGABYTE X870E AERO X3D DARK WOOD Motherboard was a stress-free experience. The Lian Li LANCOOL 217 has more than enough room, and every aspect is thoughtfully designed. Cable routing was actually guided by the instruction booklet and was very easy. The included fans were pre-installed, and if we wanted to move them, they were toolless. The included fan controller worked very well. The PSU compartment is vast once the HDD cradles are removed. The components of the case all fit together effortlessly. The fit and finish of the case is excellent. The wood trim is exceptionally well done. All in all, this case is striking to look at, and we think a great value.
The LIAN LI LANCOOL 217 Black Genuine Walnut Wood Case is designed well to show off a build with the GIGABYTE X870E AERO X3D DARK WOOD Motherboard in mind, or other similar dark-themed motherboards. Not only does the LIAN LI LANCOOL 217 Black Genuine Walnut Wood Case show off the GIGABYTE X870E AERO X3D DARK WOOD Motherboard, but it is also trying to steal the whole show. We were very impressed with the build quality and thoughtful design of this PC gaming case.
If you are looking for a build with these two choices in mind, be sure to check them out online, and just overall this case would be good for any dark-themed build as it’s a really nice case to work within. Be sure to check out our GIGABYTE X870E AERO X3D DARK WOOD Motherboard review to see how that motherboard performs.
Discussion (1 reply)
Join Discussion →Sharp looking case...
Thankfully the rough edges can be easily smoothed.
trying to think of other wood case puns... but I just can't branch out.
