Bluetooth SIG Reveals New High Data Throughput (HDT) Standard Increasing Speeds up to 7.5 Mbps, or 4x More than Current Bit Rates
Image: Bluetooth SIG
The Bluetooth Special Interest Group has announced the next standard for the popular wireless protocol, which has undergone significant changes in recent years. Bluetooth HDT (high data throughput) is a major step forward, with transfer speeds reaching up to 7.5 Mbps. The SIG has stated that this improvement could greatly reduce power usage by transmitting more data faster, allowing tasks to complete more quickly and devices to enter lower-power states sooner, but this is really only the tip of the blue iceberg that is Bluetooth HDT.
“More than a speed enhancement, Bluetooth HDT enables Bluetooth devices to transfer more data, use wireless resources more efficiently, and perform more reliably across a broader range of applications and environments.”
  • Faster data transfer: Move more data in less time — Bluetooth HDT delivers nearly four times the previous maximum Bluetooth bit rate, enabling devices to transfer substantially more information in the same amount of time. Faster data movement enables more responsive wireless interactions, shorter transfer times, and improved user experiences.
  • Increased capacity: Make room for richer experiences — Bluetooth HDT provides substantially greater capacity for wireless communication, improving spectral efficiency and creating more room for devices to exchange data within available wireless resources. This additional headroom helps Bluetooth devices support today’s more demanding applications as well as tomorrow’s innovations.
  • Better energy efficiency: Do more with available power — Bluetooth HDT moves more data in less time, allowing the radio to spend less time actively transmitting and more time in lower-power states. This helps devices deliver higher levels of performance while using energy more efficiently.
  • Enhanced reliability: Deliver more consistent performance — Bluetooth HDT improves communication robustness and resilience, helping devices maintain more consistent wireless performance across a broader and more demanding range of operating environments.
“Bluetooth® HDT brings meaningful advances in throughput, capacity, power efficiency and reliability that can help enable experiences such as high-resolution lossless audio between phones and earbuds, as well as richer AI wearable experiences that require seamless transfer of video, data and software updates between devices. Beyond these use cases, Bluetooth HDT can also help unlock new possibilities across spatial computing, industrial solutions and other connected devices. We see this as an exciting opportunity to expand what developers and device makers can build with Bluetooth.
– Chano Gómez, Senior Director, Product Management
Qualcomm Technologies, Inc.
Of course, one of the things on many people’s minds is higher audio quality. Recent advancements have seen improvements with hi-res audio options, but Bluetooth HDT could blow the barn doors wide open in offering many more opportunities for wireless audio streaming. The excitement doesn’t stop there either, as wireless VR or XR devices compatible with the new protocol will have the potential to escape the leash just as the Steam Frame has. There are commercial opportunities as well in enabling greater levels of automation via wireless connections in environments with limited cabling options. Industry partners have already begun sharing their support for Bluetooth HDT, which is expected to arrive in 2027.
“Bluetooth® HDT represents a significant advancement in wireless performance, creating opportunities for richer audio and new connected experiences on PCs and across emerging edge and IoT applications.”
– Amir Segev, General Manager, Wireless Solutions Group
Intel Corporation
Discussion (7 replies)
Well now it makes sense why everyone is using their own wireless for higher bitrate communications.
LazyGamer
LazyGamer 👍 1
Even for headsets. This might make it fast enough to have audiophile stereo and mic on a headset!
I mean you CAN get that but you pay oit the nose.
Yeah, I forget the different ones but have read about them. There's been a couple of newer compression techniques over the last couple of years but I think they top out at 24/48 or maybe 24/96 but this could potentially do much better with little or no compression needed in transmission.
Grimlakin 👍 1
Yea mine are 24/96.
LazyGamer
LazyGamer 👍 1
Anything higher than 16bit 44.1Khz is overkill for output... matters for capturing and processing audio more (but not for voice stuff captured off of headsets).
A little more on this and sad news is that we're still not quite there for 24/192 but a solid 24/96 is here. For 24/192 we're going to need 9.2 Mbps.
[URL unfurl="true"]https://www.tomshardware.com/peripherals/wearable-tech/new-bluetooth-high-data-throughput-may-finally-satisfy-audiophiles-bluetooth-hdt-offers-a-maximum-bandwidth-of-7-5mbps-allowing-true-lossless-transmission[/URL]
