JEDEC says the faster rates and wider bus deliver more than 50% more bandwidth at introduction. It also adds that this is a bandwidth target, not a claim of equivalent application performance.
Architecturally, DDR6 moves to pseudo-channels for more bandwidth per DRAM package. It switches to VSS-terminated I/O for better performance-per-watt, adds data-center-focused low-power modes, and supports multiple system ECC implementations. That shorter 74mm module is meant to let board designers pack in more memory density. JEDEC says DDR6 is being defined across RDIMM, UDIMM, and CAMM form factors, so it’s not shaping up to be CAMM-only as I initially suspected based on all of the CAMM2 noise at Computex last year. But the standard isn’t finished, and JEDEC is clearly writing it with servers and AI inference first. The JC-42 committee chair frames the whole thing around AI and data-intensive workloads.
For context, DDR5 RDIMMs top out at 9.2 GT/s in JEDEC’s spec. Enthusiast DDR5 UDIMMs already blow past that with XMP and EXPO, as our DDR5-8000 testing on Ryzen showed. Expect the same pattern with DDR6: JEDEC sets the floor, and the overclockers set the ceiling.
The memory market is a mess, with the big three DRAM makers facing a price-fixing lawsuit that just survived a motion to dismiss. Meanwhile, DDR4 keeps refusing to die on new Intel platforms. A new standard aimed at data centers first suggests DDR6 desktop kits are a long way off, and won’t be cheap when they arrive.
