Phantom Blade Zero Performance & IQ
Written reviews:
- The FPS Review: https://www.thefpsreview.com/2026/11/23/phantom-blade-zero-performance-iq-review/
- TechPowerUp: https://www.techpowerup.com/review/phantom-blade-zero-performance-benchmark/
Consensus summary: We ran S-GAME’s Unreal Engine 5 action RPG across NVIDIA’s lineup plus a Radeon RX 9070 XT. The big finding is that path tracing transforms the game: ReSTIR GI replaces Lumen and adds ray-traced water caustics, and the standard ray tracing mode ends up feeling redundant next to it. Native DLSS 4.5 and FSR 4.1 make Balanced upscaling perfectly usable. 2X frame generation also felt surprisingly smooth even at lower base framerates. TechPowerUp’s broader 35-GPU sweep, which calls this the first major Unreal Engine 5.7 title, rounds things out with VRAM usage and upscaling comparisons.
FPS Review take: For midrange owners, our advice is to skip path tracing and run Ultra with upscaling rather than dropping below the High preset, which gives up too much visually. If you have the GPU for it, though, this is one of the rare path tracing implementations that justifies its cost.
Radeon RX 9070 XT vs. Radeon RX 7900 XTX: FSR 4.1 Benchmark
Written reviews:
Video reviews:
- Hardware Unboxed: https://www.youtube.com/watch?v=DH1lgQuOZxk
Consensus summary: In October, TechSpot’s 50-plus game comparison of these two cards ended in a near tie: the 9070 XT was 2-3% faster at 1440p, and the 7900 XTX led by about 1% at 4K. That same piece raised the question this follow-up tries to answer. RDNA 3 runs FSR 4.1 through INT8 instead of FP8, and AMD puts its upscaling cost at roughly 3.1 ms at 4K on the 7900 XTX versus 1.3 ms on the 9070 XT. Hardware Unboxed’s new video turns FSR 4.1 on for both cards across 15 games at 1440p and 4K, including Crimson Desert, Battlefield 6, Forza Horizon 6, and 007 First Light.
FPS Review take: This is a different question from October’s raw-performance comparison. Native, the two cards are nearly tied; with FSR 4.1 on, the 7900 XTX’s higher upscaling overhead could matter. FSR 4.1 keeps spreading, from DOOM: The Dark Ages becoming the first Vulkan game with FSR 4.1 to No Man’s Sky picking up FSR 4 via AMD’s FSR 2.4 Vulkan update.
Samsung Odyssey G8 G80SH 32″ (4K 240 Hz QD-OLED)
Written reviews:
- Tom’s Hardware: https://www.tomshardware.com/monitors/gaming-monitors/samsung-odyssey-g8-g80sh-32-inch-4k-oled-gaming-monitor-review
- PCWorld: https://www.pcworld.com/article/3241446/samsung-odyssey-g80sh-review.html
- RTINGS: https://www.rtings.com/monitor/reviews/samsung/odyssey-oled-g80sh-s32hg802s
Consensus summary: Tom’s Hardware gave the G80SH an Editor’s Choice and calls its HDR some of the best it has seen recently. Its factory calibration is close to perfect: gamma ran slightly light, which two clicks on the slider fixed. Its Auto color space mode renders sRGB for SDR and the full gamut for HDR, a feature few monitors offer. PCWorld also awarded it an Editor’s Choice and singled out its suitability for creative editing. The complaints are minor: no frame counter and no built-in speakers. In exchange, you get a 98 W USB-C port and an ergonomic stand that Tom’s describes as rock solid.
FPS Review take: Tom’s Hardware’s own condition is the one that matters: if Samsung keeps this under $1,000, it is an easy recommendation for anyone who games and works on the same screen. Samsung is pushing the other way too, with the 1,100 Hz dual-mode Odyssey G6 (G60H) for players who care more about motion than pixels.
ASRock Taichi TCO27QXA (27″ QHD 500 Hz QD-OLED)
Written reviews:
Consensus summary: ASRock’s first Taichi-branded OLED pairs a 27-inch QD-OLED panel with a 500 Hz refresh rate and a 0.03 ms response time. FunkyKit came away impressed with its clarity, smoothness, and responsiveness. The feature list is unusually long for this class: dual HDMI 2.1 and dual DisplayPort 2.1, USB-C with 65 W charging, a built-in KVM, stereo speakers, and Taichi rear lighting. FunkyKit lists it at around $749 at Newegg and acknowledges that the QHD resolution isn’t the highest available, but concludes that speed and image quality make up for it.
FPS Review take: At this price, it competes directly with established 500 Hz QD-OLEDs. The KVM and dual DisplayPort 2.1 inputs are what set it apart, so it is worth a look if you plan to run more than one system from it. One review is a thin basis for a verdict, so we’d wait for more coverage, especially burn-in mitigation testing, before committing.
Montech CyberFlow ARGB 360
Written reviews:
- TechPowerUp: https://www.techpowerup.com/review/montech-cyberflow-argb-360-aio-liquid-cpu-cooler/
- KitGuru: https://www.kitguru.net/components/cooling/james-dawson/three-way-aio-review-cougar-deepcool-and-montech-tested/
Consensus summary: The reviews disagree sharply. TechPowerUp says the CyberFlow performs like a heavyweight: tremendous cooling, a thick radiator, daisy-chained fans, a magnetic VRM fan, and a six-year warranty, with noise and a few quirks as the trade-off. KitGuru’s three-way test from earlier this autumn found the opposite. There, the CyberFlow 360 ran at 59 dBA against the Cougar LQX Pro 360’s 48 dBA and averaged 67°C over ambient against the Cougar’s 60°C, leaving it at the bottom of the group in KitGuru’s harder load test. Both reviews agree that it is loud.
FPS Review take: Results this far apart usually come down to fan curves, mounting, or test load, so check which methodology looks more like your build before buying. The magnetic VRM fan is a genuinely useful extra for anyone running a hot AM5 board in a low-airflow case.
ASRock X870E Challenger Wi-Fi White
Written reviews:
- TechPowerUp: https://www.techpowerup.com/review/asrock-x870e-challenger-wi-fi-white/
- TweakTown: https://www.tweaktown.com/reviews/11610/asrock-x870e-challenger-wi-fi-white-x870e-with-a-b850-price/index.html
- Wccftech: https://wccftech.com/review/asrock-x870e-challenger-wifi-white-motherboard-review/
- Tom’s Hardware: https://www.tomshardware.com/pc-components/motherboards/asrock-x870e-challenger-wifi-motherboard-review
Consensus summary: TechPowerUp’s late review lands where the summer reviews did: this is X870E for well under $300, with excellent performance, and the board comes in black or white. The catch, in TechPowerUp’s view, is very stiff competition. TweakTown scored it 95% and called it X870E at a B850 price. Wccftech found the 20+2+1 VRM ran cool and stable at $229. Tom’s Hardware called it one of the best-equipped sub-$230 X870E boards, with the 160 MHz Wi-Fi 7 implementation as the only real compromise.
FPS Review take: We reached a similar conclusion in our own ASRock X870E Challenger WiFi review: Wi-Fi 7, USB4, 5 GbE, and four M.2 slots make it one of the easiest AM5 recommendations for builders who want X870E without the premium price.
Logitech G PRO X2 RAPID 8K
Written reviews:
- TweakTown: https://www.tweaktown.com/reviews/11676/logitech-g-pro-x2-rapid-8k-logis-best-analog-gaming-keyboard-to-date/index.html
- TechRadar: https://www.techradar.com/computing/logitech-g-pro-x2-rapid-review
- Tom’s Guide: https://www.tomsguide.com/computing/keyboards/logitech-g-pro-x2-rapid-review
- Insider Gaming: https://insider-gaming.com/reviews/logitech-pro-x2-rapid-keyboard-review/
Consensus summary: Everyone agrees this is the best-feeling keyboard Logitech has made. TweakTown gave it 91% and credits six layers of dampening for its acoustics and typing feel, on top of responsive analog switches and 8K polling. Insider Gaming called it its new favorite. The split is over value. TechRadar thinks it is great for serious esports players but notes the largely plastic build and a weak wrist rest. Tom’s Guide is more skeptical: it argues cheaper rivals offer more features and that 8K polling isn’t a reason to buy a keyboard. The common complaint is $229.99 for a wired-only board.
FPS Review take: When Logitech announced the PRO series alongside the PRO X3 Superstrike, the magnetic-switch keyboard looked like the afterthought. The reviews suggest the reverse: build quality is the reason to buy it, not the spec sheet.
Power Supplies: be quiet! Power Zone 2 1000W and Moaiplay Ora Pro G1 850
Written reviews:
- FunkyKit: https://www.funkykit.com/reviews/power-supplies/be-quiet-power-zone-2-1000w-psu-review/
- TechPowerUp: https://www.techpowerup.com/review/moaiplay-ora-pro-g1-850/
Consensus summary: Both units are built around quiet operation. FunkyKit gave the Power Zone 2 1000W its Editor’s Choice and calls it one of the best PSUs it has reviewed. Its noise was indistinguishable from the room’s, thanks to a zero-RPM 140 mm Pure Wings 3 fan, and it carries Platinum efficiency from both 80 PLUS and Cybenetics, a native 12V-2×6 cable with a 90-degree connector, and a 10-year warranty. TechPowerUp found Moaiplay’s Ora Pro G1 850 whisper-quiet behind a 148 mm fan, with strong Gold efficiency, Japanese capacitors, and the same 10-year warranty in a compact ATX 3.1 chassis.
FPS Review take: The be quiet! is the safer high-wattage pick if you can find one; FunkyKit notes it is easy to buy in the EU and Canada but scarce at major US retailers. The Moaiplay is a less familiar name, but a 10-year warranty is a reasonable sign of confidence.
NAS: UGREEN NASync DXP6800 Ultra and Rosewill HEARTH NAS PRO MAX
Written reviews:
Video reviews:
- Level1Techs: https://www.youtube.com/watch?v=Fa–qwO5Zg8
Consensus summary: TweakTown gave UGREEN’s six-bay DXP6800 Ultra appliance 89%, praising dual 10 GbE plus Thunderbolt, an Intel Core 5 120U, a PCIe Gen4 x4 slot, and room for up to 208 TB. Its complaints were the 8 GB base RAM, the lack of hybrid RAID, and how quickly the total cost climbs once it is filled with drives and memory. Level1Techs’ Wendell looked at the DIY route with Rosewill’s HEARTH NAS PRO MAX chassis for homelab builds; the video’s title sums up its argument: expensive isn’t always better.
FPS Review take: For anyone weighing a turnkey NAS against rolling their own, these two make a useful pair: the UGREEN is the convenient option, and Wendell is the right guide if you’d rather assemble one yourself.
