Transient Testing
Transient Test 1
Loaded/Unloaded
12v/5v
Test #1 is equal to approximately 25% of the rated capacity of the SilverStone SX700-G at 45c. This makes Test #1 equal to 184W by loading the 12v rail to 13a, the 5v rail to 2a, the 3.3v rail to 1a, the +5vsb to 2a, and the -12v to 0.3a before the addition of the transient load. The results of Test #1 show a ~400mV drop on the 12v rail and ~60mV drop on the 5v rail when each is directly loaded. At the same time that the load was being triggered on the 12v rail, the 5v rail measured a ~55mV drop.
Transient Test 2
Loaded/Unloaded
12v/5v
Test #2 is equal to approximately 50% of the rated capacity of the SilverStone SX700-G at 45c. This makes Test #2 equal to 325W by loading the 12v rail to 24a, the 5v rail to 3a, the 3.3v rail to 2a, the +5vsb to 2a, and the -12v to 0.3a before the addition of the transient load. The results of Test #2 show a ~330mV drop on the 12v rail and ~60mV drop on the 5v rail when each is directly loaded. At the same time that the load was being triggered on the 12v rail, the 5v rail measured a ~50mV drop.
The Transient Load Tests results for the SilverStone SX700-G are passing and generally good. In today’s testing, the SX700-G saw the loaded 12v rail post a peak change of ~400mV and the loaded 5v rail post a peak change of ~60mV. The unloaded 5v peak change during the 12v load was ~55mV. Those numbers are, in an absolute sense, good for the 5v rail. The 12v rail results are good in a relative sense when we consider that this unit is an SFX product. However, this unit does trail what we saw from the FSP Dagger 600W even though that unit is 100W smaller in capacity. Let’s move on now to see how this unit does in the DC Output Quality aspect of our testing!
