ASUS has taken notice of the Intel’s new mini powerhouse PC’s and has released two models of the NVIDIA RTX 2070 for them. These cards are designed with the new NUC 9 Extreme and Pro Kits in mind but can also be used in small form factor builds. The two variants are the O8G(overclocked) and 8G(standard). The “Dual” in the name represents that this is a dual slot/dual fan card and not a dual GPU.
SPECIFICATIONS DUAL-RTX2070-O8G-MINI
- NVIDIA® CUDA® Cores: 2304
- OC mode Boost Clock: 1680 MHz
- Gaming mode Boost Clock: 1650 MHz
- 8 GB GDDR6 memory
- Memory Clock: 14000 MHz
- PCIe Interface: 3.0
- 1x DVI-D
- 1x Native HDMI 2.0b
- 1 x Native DisplayPort 1.4
SPECIFICATIONS DUAL-RTX2070-8G-MINI
- OC mode Boost Clock: 1650 MHz
- Gaming mode Boost Clock: 1620 MHz
- 8 GB GDDR6 memory
- 1x DVI-D
- 1 x Native HDMI 2.0b
ASUS has worked with Intel to ensure a that temperatures are kept in check with a custom design for the NUC 9’s. They’ve customized the shroud, heatsink, and heat pipes to facilitate improved cooling.
