ID-COOLING has announced SE-914-XT Series CPU air cooler, featuring a comparatively big heatsink in the section of 130 mm height. Both coolers have 4 direct-touch copper heatpipes, 92 mm PWM fan and newly designed metal-mecha mounting system which is proved user friendly on the previous SE-224-XT series. Model names are: SE-914-XT ARGB & SE-914-XT BASIC.
With a quite thick heatsink design, these two coolers are designed for a TDP max at 150 W. In a height of 131 mm for the ARGB version / 126 mm for the Basic version, they can fit very well into medium size cases. ARGB version has a black heatsink and a top ARGB cover while BASIC version has only a top black sticker for a stealthy look.
Both coolers has a 92x92x25mm fan running at 600 to 2200rpm with PWM support while pushing 45.8CFM air at maximum speed. An extra fan clip set is included for a push-pull configuration. ARGB version has separate 5 V 3pin ARGB cable from the fan and cable controller for users who don’t have a RGB ready motherboard.
The bundled thermal grease is named ID-TG25, which has a thermal conductivity of 10.5 W/m-K.
The newly designed metal-mecha mounting system provides secure installation of the cooler. The two coolers are compatible with all mainstream CPU sockets, including Intel LGA2066/2011/1200/1150/1151/1155/1156 and AMD AM4.
- MSRP for SE-914-XT ARGB: 34.99USD.
- MSRP for SE-914-XT BASIC: 24.99USD.
- Available date: Mid-August, 2020.
