Those of you who were able to score a GeForce RTX 3080 FTW3 ULTRA but desired more power are in luck, as EVGA has released a new beta BIOS that increases its ceiling admirably. The update, which was shared by EVGA product manager Jacob Freeman last night, boosts the GeForce RTX 3080 FTW3 ULTRA’s power limit from 400 W to 450 W. This should come in handy for overclockers who want to stretch and maximize the GPU’s potential.
We’ve copied Freeman’s forum post below, which includes instructions on how to download and install the BIOS. Before getting too crazy, users should ensure that they have a proper cooling setup and capable power supply (e.g., 850 W PSU that’s 80 Plus Gold certified).
New XOC BIOS for 3080 FTW3 ULTRA available now https://t.co/sZFVRZkepn pic.twitter.com/hbAAxBSZj7
— Jacob Freeman (@EVGA_JacobF) October 15, 2020
Due to many users request, have a new BETA BIOS that increases the maximum Power Target. This BIOS is only intended for the extreme overclocking user and does not have any other changes. Please note the following:
- This update will increase the power consumption while overclocking, and is recommended you have adequate cooling and power (850w+ Gold minimum) when using this.
- EVGA does not guarantee any performance increase or overclock while using this BIOS update.
BIOS Instructions (Windows Installation):
- Download the correct .zip file below for your graphics card below.
- Extract the files to a location on disk.
- Make sure no programs are running in the background, and double click Update.exe
- Press “Y” to begin the update.
- DO NOT TURN OFF POWER OR RESET DURING THE UPDATE PROCESS!
- After update, restart PC.
EVGA GeForce RTX 3080 FTW3 ULTRA
- EVGA GeForce RTX 3080 FTW3 ULTRA – BIOS 1 (Normal) |BIOS 2 (OC)
NOTE: There are 2 BIOS’s, one is for the BIOS when switched to the normal stock position, the other if switched to the OC position.
