LIAN LI has expanded upon its popular lineup of PC-011D cases with a new variant, the O11 Dynamic Mini. Despite being the most compact edition in the series (420 mm x 269.5 mm x 380 mm), it continues the tradition of offering ample space for water-cooled setups and a multi-chamber design for increased drive capacity and simpler cable management. A modular back panel allows the user to pick between a 3-, 5-, or 7-slot configuration.
LIAN LI’s O11 Dynamic Mini will be available in both black and white colors for an MSRP of $99. Preorders open on November 20th, 2020, and optional accessories, such as a replacement backplate to mount the GPU vertically and a hot-swap backplate add-on for the drive cage, will be released shortly after launch.
Specifications
| Model | O11D MINI |
| Dimensions | (D) 420mm x (W) 269.5mm x (H) 380mm |
| Motherboard | E-ATX(width: under 280mm)/ATX/M-ATX/ITX |
| PSU | SFX / SFX-L |
| Color | Black / White |
| Materials | 0.8mm SPCC (Body) 1.0mm SPCC (Interior, back panel) 4.0mm Tempered glass 2.0mm Aluminum (White top and front panel) Acrylic (Black top panel) |
| Fan Support | Top: 3x 120mm or 2x 140mm Side: 2x 120mm or 2x 140mm Bottom: 3x 120mm or 2x 140mm Rear: 1x 120mm |
| Radiator | Top: 1x 360mm or 280mm radiator or 240mm radiator Side: 1x 240mm or 1x 280mm radiator Bottom: 1x 360mm or 280mm radiator or 240mm radiator |
| GPU Length Clearance | 395mm |
| CPU Cooler Height Clearance | 170mm |
| Drive | Right side: 2x 2.5” SSD Hard Drive Cage: 2x 3.5” HDD or 2x 2.5” SSD |
| Expansion slots | 3 or 5 or 7 slots (depends on backplate) |
| I/O Ports | 1x HD Audio 2x USB 3.0 1x USB 3.1 TYPE-C 1x Power button |
| Dust Filters | 1x Top (magnetic) 2x Right side (magnetic) 1x Bottom (tray) |
Original Press Release
LIAN LI Industrial Co. Ltd., a leading manufacturer of aluminum chassis and PC accessories, is proud to launch the PC-O11D MINI, the newest and most compact addition to the O11D series. Available in white with aluminum accents, and black with a glossy finish, the O11D MINI takes on a highly modular approach to accommodate mini-ITX, mATX, ATX, and E-ATX motherboard sizes while still offering high-performance water cooling configurations. With its modular and interchangeable back panel, and included pump mounts, the O11D MINI brings a new level of DIY to the PC industry while keeping a minimalistic and modern design.
Perfect for E-ATX to M-ITX
The O11D MINI supports a wide range of configurations with a modular rear panel. Adjustable into 3 positions, the I/O shield rear panel can be positioned at the top with 7 expansion slots, in the middle with 5 expansion slots, and at the bottom with 3 expansion slots. Each bracket can be easily removed and relocated to support either large E-ATX to M-ATX motherboards (with the addition of an included extension bar next to the motherboard tray) or small ITX motherboards, which offer the most room for custom water cooling.
Cooling compatibility in mind
The O11D MINI offers endless possibilities for optimal cooling configurations. The well thought out filtered vents and multiple mounting points for radiators and fans at the top, bottom, and beside the motherboard, can adapt to an all-air cooling, full custom water cooling, or a mix of AIO and air cooling system. Depending on the location and size of the motherboard installed, up to 9 fans can be fitted in the chassis, or even a 360mm thick radiator at the top or bottom with a 280 radiator beside the motherboard, offering enough flexibility to choose a well-adapted thermal solution and prevent any system from throttling.
A special touch for custom water cooling
The O11D MINI comes with pump mounting brackets in 3 different styles, which gives more flexibility for vertical and horizontal alignment of the pump. All fitted with elongated holes for adjustment, the pump can be mounted at the bottom of the case, in a raised position, or on top of a radiator or fan.
Updated look
Following the design of the O11D series, the O11D MINI brings in small changes giving it a clean modern look. Starting with airflow, the top, rear, and bottom ventilation holes now feature a honeycomb pattern for improved performance. While the white version sports an elegant brushed aluminum strip at the front of the case, the black version replaces this strip with glass and adds acrylic (with brushed silkscreen underneath) at the top. Both versions feature the same IO at the top, which includes one audio/mic jack, two USB 3.0 ports (Type-A), one USB 3.1 port (Type-C), and a power button.
The O11D MINI black and white are available for pre-order starting November 20th, 2020, at MSRP $99.00 USD. Optional accessories will soon be available after launch, including a replacement backplate to mount the GPU vertically, as well as a hot-swap backplate add-on for the drive cage. In addition, a version of the O11D MINI including a fully modular 700 watt 80+ Gold SFX PSU will be available in the near future.
