Lenovo has revealed three unannounced NVIDIA GeForce RTX graphics cards. The details can be found on the product specifications page for its new Legion R5 28IMB05 gaming desktop. There’s the NVIDIA GeForce RTX 3050, 3050 Ti, and 3060.
Graphics Options
| Graphics | Type | Memory | Connector | Max Resolution | Key Features |
| AMD Radeonâ„¢ RX 5500 | Discrete | 4GB GDDR6 | 1x HDMI® 2.0, 3x DP 1.4 | 4096×2160@60Hz(HDMI), 7680×4320@60Hz(DP) | DirectX® 12 |
| NVIDIA® GeForce® GTX 1650 SUPER | Discrete | 4GB GDDR6 | 1x HDMI 2.0b, 2x DP 1.4 | 7680×4320 @60Hz(DP) | DirectX 12 |
| NVIDIA GeForce GTX 1660 SUPER | Discrete | 6GB GDDR6 | 1x DVI, 1x HDMI 2.0b, 1x DP 1.4 | 7680×4320@60Hz(DP) | DirectX 12 |
| NVIDIA GeForce RTXâ„¢ 2060 CD | Discrete | 6GB GDDR6 | 1x HDMI 2.0b, 3x DP 1.4 | 4096×2160@60Hz(HDMI), 7680×4320@60Hz with DSC(DP) | DirectX 12 |
| NVIDIA GeForce RTX 2070 CD | Discrete | 8GB GDDR6 | 1x HDMI 2.0b, 3x DP 1.4 | 7680×4320@60Hz(DP) | DirectX 12 VR ready |
| NVIDIA GeForce RTX 2070 SUPER | Discrete | 8GB GDDR6 | 1x HDMI 2.0b, 1x USB Type-C Gen 2, 3x DP 1.4 | 7680×4320@60Hz(DP) | DirectX 12 VR ready |
| NVIDIA GeForce RTX 3050 | Discrete | 4GB GDDR6 | 1x DP 1.4a, 1x HDMI 2.1, 1x DVI | 7680×4320@60Hz(HDMI); 7680×4320@60Hz(DP) | DirectX 12 |
| NVIDIA GeForce RTX 3050 Ti | Discrete | 6GB GDDR6 | 3x DP 1.4a, 1x HDMI 2.1 | 7680×4320@60Hz(HDMI), 7680×4320@60Hz(DP) | DirectX 12 |
| NVIDIA GeForce RTX 3060 | Discrete | 12GB GDDR6 | 3x DP 1.4a, 1x HDMI 2.1 | 7680×4320@60Hz(HDMI), 7680×4320@60Hz(DP) | DirectX 12 |
| NVIDIA GeForce RTX 3070 | Discrete | 8GB GDDR6 | 3x DP 1.4a, 1x HDMI 2.1 | 7680×4320@60Hz(HDMI); 7680×4320@60Hz(DP) | DirectX 12 |
If accurate, this chart settles a number of rumors about GeForce RTX 3060 variants. It appears that there will be no 6 GB version, which coincides with new EEC filings by GIGABYTE. Both the GeForce RTX 3060 and GeForce RTX 3050 Ti are expected to have a 192-bit memory bus. Strangely, the GeForce RTX 3070 Ti is rumored to only have 10 GB of GDDR6X memory, while the GeForce RTX 3060 has 12 GB of GDDR6 memory.
Rumored GeForce RTX Cards
| Card Name | GPU | CUDA Cores | Memory Size | Memory Bus | TGP |
| GeForce RTX 3050 | GA-107-300 | 2304 | 4 GB (GDDR6) | 128-bit | 90 W |
| GeForce RTX 3050 Ti | GA-106? | 3584 | 6 GB (GDDR6) | 192-bit | ? |
| GeForce RTX 3060 | GA-106 | 3840 | 12 GB (GDDR6) | 192-bit | ? |
| GeForce RTX 3070 Ti | GA-102-150 | 7424 | 10 GB (GDDR6X) | 320-bit | 320 W |
| GeForce RTX 3080 Ti | GA-102-150 | 10496 | 20 GB (GDDR6x) | 320-bit | 320 W |
