Thermaltake has announced its TOUGHLIQUID line of AIO liquid cooler products, which includes radiators ranging in size from 240 mm to 360 mm. The TOUGHLIQUID ULTRA models feature an LCD screen for monitoring and displaying data, while the TOUGHLIQUID ARGB models swap that for RGB.
Original Press Release
Thermaltake, the leading PC component brand offering premium solutions for cooling, gaming peripherals, and enthusiast memory, today is proud to announce the TOUGHLIQUID Series, the newest member of the Thermaltake AIO liquid cooler line up. TOUGHLIQUID ULTRA and TOUGHLIQUID ARGB Sync are built using the TOUGHFAN 12 high-performance fans to deliver superior cooling performance and stability for system builders. Offering a variety of models, supporting radiator sizes including 240mm, 280mm, and 360mm, equipped with a LED display or RGB on the pump.
“Intuitive hardware monitoring and advanced personalization are what the THOUGLIQUID ULTRA series brings to the market,” said Kenny Lin, the CEO of Thermaltake. “The important information like CPU temperature, frequency, and performance usage can be displayed in real-time on the smart 2.1″ LCD monitor. Users can also personalize the display with GIF pictures or with custom RGB lighting modes through our RGB software. Thermaltake is giving PC builders even more customization options with this next-gen AIO watercooler.”
TOUGHLIQUID ULTRA series
The TOUGHLIQUID ULTRA comes packed with additional features and upgrades, including the high-performance TOUGHFAN 12 Turbo series radiator fans with an impressive 2,500RPM maximum speed offering stronger airflow for enhanced cooling. This new fan incorporates the 2nd-generation hydraulic bearing and LCP blades for maximum cooling performance and quiet operation. The TOUGHLIQUID ULTRA features a redesigned radiator with more fin surface area for excellent thermal efficiency and is now available in 240mm or 360mm form factors. The integrated water pump comes with a full copper base plate for outstanding heat conductivity, and the entire cooler comes pre-refilled for zero maintenance and long-lasting operation.
The water block mounted LCD screen is able to display real-time monitoring of multiple hardware components, lighting effects, and customized GIF files featuring our new TT RGB Plus 2.0 software. Sync up with other TT RGB Plus products to create beautiful lighting effects, across multiple levels, all from our NEW 2.0 Software.
The TOUGHLIQUID ARGB Sync follows in the series designed more budget-friendly, adding some RGB instead of an LCD screen, gain great performance with our high-performance TOUGHFAN 12 radiator fans with 2,000RPM for strong airflow and enhanced radiator cooling. The TOUGHFAN utilized the same fan bearing and blades as the ULTRA series for superior cooling performance and quiet operation. This ARGB Sync Edition also uses the same upgraded radiator with more fin surface area and will be available in 240mm, 280mm, and 360mm form factors.
Six addressable LEDs are embedded in the pump block. Featuring a copper cold plate design and rotatable LED cap with 360° rotational orientation. The built-in controller integrated with the water saves space without the need for an external controller to manage, allowing users to connect and set lighting modes, speeds, and colors. SYNC UP the TOUGHLIQUID ARGB to a variety of 5V+ capable motherboards for easy SYNC and control of the RGB all from one software.
Backed by a limited 2-year warranty, TOUGHLIQUID ULTRA, and TOUGHLIQUID ARGB Sync will be available in the USA and Canada in Q1 2021.
MSRP:
TOUGHLIQUID ULTRA 240: $209.99
TOUGHLIQUID ULTRA 360: $239.99
TOUGHLIQUID ARGB 240 $119.99
TOUGHLIQUID ARGB 280 $129.99
TOUGHLIQUID ARGB 360 $149.99
