It was recently revealed that many laptop manufacturers would not be indicating whether GeForce 30 Series mobile GPUs were of the Max-P or Max-Q variety, making it harder for buyers to identify the model that best suits their needs. Presently there are three base models, the GeForce RTX 3060, 3070, and 3080 mobile. ComputerBase obtained a list of the many variants.
The GeForce RTX 3060 mobile uses the GA106 GPU. Power has been reduced from 60 to 115 watts vs. the desktop version (170 watts). It also features 256 more CUDA cores but half the memory. Interestingly, the most powerful version of RTX 3060 mobile comes closest to resembling its desktop counterpart. The base clock is slightly higher, while the boost has been reduced.
GeForce RTX 3060 Mobile
| Model Version | TDP | CUDA Cores | Base Clock | Boost Clock | Memory Bus | Memory Speed |
| RTX 3060 laptop GPU Max-Q | 60 W | 3,840 | 817 MHz | 1,282 MHz | 192 bits | 12 Gbps |
| RTX 3060 laptop GPU Max-Q | 65 W | 3,840 | 975 MHz | 1,357 MHz | 192 bits | 12 Gbps |
| RTX 3060 laptop GPU Max-Q | 70 W | 3,840 | 1,050 MHz | 1,402 MHz | 192 bits | 12 Gbps |
| RTX 3060 laptop GPU | 80 W | 3,840 | 900 MHz | 1,425 MHz | 192 bits | 14 Gbps |
| RTX 3060 laptop GPU | 85 W | 3,840 | 1,035 MHz | 1,485 MHz | 192 bits | 14 Gbps |
| RTX 3060 laptop GPU | 90 W | 3,840 | 1,163 MHz | 1,530 MHz | 192 bits | 14 Gbps |
| RTX 3060 laptop GPU | 95 W | 3,840 | 1,215 MHz | 1,567 MHz | 192 bits | 14 Gbps |
| RTX 3060 laptop GPU | 100 W | 3,840 | 1,267 MHz | 1,605 MHz | 192 bits | 14 Gbps |
| RTX 3060 laptop GPU | 105 W | 3,840 | 1,305 MHz | 1,642 MHz | 192 bits | 14 Gbps |
| RTX 3060 laptop GPU | 110 W | 3,840 | 1,342 MHz | 1,680 MHz | 192 bits | 14 Gbps |
| RTX 3060 laptop GPU | 115 W | 3,840 | 1,387 MHz | 1,702 MHz | 192 bits | 14 Gbps |
The GeForce RTX 3070 mobile features the same GA104 GPU as the desktop version. Power has been reduced from 220 watts to 80 to 125 watts. CUDA Cores have been reduced from 5888 to 5120. The boost clocks have also been significantly reduced, while the higher-end models have the same memory specs.
GeForce RTX 3070 Mobile
| RTX 3070 laptop GPU Max-Q | 80 W | 5,120 | 780 MHz | 1290 MHz | 256 bit | 12 Gbps |
| RTX 3070 laptop GPU Max-Q | 85 W | 5,120 | 855 MHz | 1365 MHz | 256 bit | 12 Gbps |
| RTX 3070 laptop GPU Max-Q | 90 W | 5,120 | 930 MHz | 1410 MHz | 256 bit | 12 Gbps |
| RTX 3070 laptop GPU | 115 W | 5,120 | 1.110 MHz | 1,560 MHz | 256 bit | 14 Gbps |
| RTX 3070 laptop GPU | 120 W | 5,120 | 1,170 MHz | 1,590 MHz | 256 bit | 14 Gbps |
| RTX 3070 laptop GPU | 125 W | 5,120 | 1,215 MHz | 1,620 MHz | 256 bit | 14 Gbps |
The GeForce RTX 3080 mobile is based on the GA104 GPU. Even the most powerful version uses less than half the wattage of the Founders Edition. It also has 2560 fewer CUDA cores. Instead of 10 GB of 19 Gbps GDDR6 memory, it comes with either 8 GB or 16 GB operating at 12 Gbps or 14 Gbps on a 256-bit bus. One review has shown that it trades blows with RTX 3070 mobile and comes out ahead on some occasions.
GeForce RTX 3080 Mobile
| RTX 3080 laptop GPU Max-Q | 80 W | 6,144 | 780 MHz | 1245 MHz | 256 bit | 12 Gbps |
| RTX 3080 laptop GPU Max-Q | 85 W | 6,144 | 870 MHz | 1320 MHz | 256 bit | 12 Gbps |
| RTX 3080 laptop GPU Max-Q | 90 W | 6,144 | 930 MHz | 1365 MHz | 256 bit | 12 Gbps |
| RTX 3080 laptop GPU | 115 W | 6,144 | 1.110 MHz | 1,545 MHz | 256 bit | 14 Gbps |
| RTX 3080 laptop GPU | 120 W | 6,144 | 1,155 MHz | 1,575 MHz | 256 bit | 14 Gbps |
| RTX 3080 laptop GPU | 125 W | 6,144 | 1,185 MHz | 1,605 MHz | 256 bit | 14 Gbps |
| RTX 3080 laptop GPU | 130 W | 6,144 | 1,230 MHz | 1,635 MHz | 256 bit | 14 Gbps |
| RTX 3080 laptop GPU | 135 W | 6,144 | 1,260 MHz | 1,665 MHz | 256 bit | 14 Gbps |
| RTX 3080 laptop GPU | 140 W | 6,144 | 1,275 MHz | 1,665 MHz | 256 bit | 14 Gbps |
| RTX 3080 laptop GPU | 145 W | 6,144 | 1,320 MHz | 1,695 MHz | 256 bit | 14 Gbps |
| RTX 3080 laptop GPU | 150 W | 6,144 | 1,350 MHz | 1,710 MHz | 256 bit | 14 Gbps |
