SilverStone is releasing a new batch of its SX1000 power supplies in February. Initially announced in November with a planned release of Q4 2020, the world’s first SFX 1000-watt PSU was pulled from retailers due to a fan controller issue.
“As a precaution, our limited first quantity in Europe was pulled to ensure the fan controller issue reported by a number of users in North America was not present. The second batch, which are checked will be arriving in Europe by the end of February.”
The SX1000 is aimed at builds with power-hungry CPUs and GPUs. This fully modular PSU has a variety of protection features, such as overcurrent protection (OCP), overpower protection (OPP), and short circuit protection (SCP). It comes in matte black and includes an assortment of cables.
Specifications
- Model Number: SST-SX1000-LPT
- Maximum DC output: 1000W
- Color: Black(Lead-Free Paint)
- Combined +3.3V & +5V: 125W
- Combined +12V: 999.6W
- Input Voltage: 90V-264V
- Input Frequency Range: 47Hz – 63Hz
- PFC: Active PFC (PF> 0.9, at full load)
- Effeciency: 89% ~ 92%, load 20% ~ 100%
- MTBF: 100,000 hours
- Operating Temperature: 0 ° C ~ 50 ° C
- Protective Functions: Overcurrent protection, Overoutput protection, Overvoltage protection, Short circuit protection, Overheat protection
- Connectors: 1 x 24 / 20-pin motherboard connector connector 300mm), 2 x 8/4 pin EPS / ATX 12V connector (“400mm” x 2), 6 x 8/6 pin PCIE connector (“400mm / 150mm” x3), 8 x SATA connector (“300mm / 200mm / 100mm / 100mm” x 2), 3 x 4 peripheral pin connector (300mm / 200mm / 200mm), 1 x 4 pin Floppy connector (100mm)
- Cooling: 1 x 120mm dual ball bearing fan
- Form Factor: SFX-L
- Noise Level: 0 ~ 36 dBA
- Dimensions: 125 mm (W) x 63.5 mm (H) x 130 mm (D)
- Certification: 80 PLUS Platinum
- Compatibility: ATX12V v2.4
Load Range
| 3.3V | 5V | 12V | 5VSB | -12V | |
| Maximum current (A) | 25A | 25A | 83.3A | 3.0A | 0.3A |
| Peak current (A) | / | / | / | / | / |
| Minimum current (A) | 0A | 0A | 0A | 0A | 0A |
| Range (%) | ± 3% | ± 3% | ± 3% | ± 5% | ± 10% |
| Line control (%) | ± 1% | ± 1% | ± 1% | ± 1% | ± 1% |
| Ripple (mVp-p) | 40mV | 40mV | 100mV | 40mV | 80mV |
