Transient Testing
Transient Test 1
12v Loaded/5v Loaded/5v Unloaded
12v/5v
Test #1 is equal to approximately 25% of the rated capacity of the SilverStone SX750 at 45c. This makes Test #1 equal to 184W by loading the 12v rail to 13a, the 5v rail to 2a, the 3.3v rail to 1a, the +5vsb to 2a, and the -12v to 0.3a before the addition of the transient load. The results of Test #1 show a ~300mV drop on the 12v rail and ~20mV drop on the 5v rail when each is directly loaded. At the same time that the load was being triggered on the 12v rail, the 5v rail measured a ~20mV drop.
Transient Test 2
12v/5v
Test #2 is equal to approximately 50% of the rated capacity of the SilverStone SX750 at 45c. This makes Test #2 equal to 367W by loading the 12v rail to 27a, the 5v rail to 4a, the 3.3v rail to 2a, the +5vsb to 2a, and the -12v to 0.3a before the addition of the transient load. The results of Test #2 show a ~200mV drop on the 12v rail and ~20mV drop on the 5v rail when each is directly loaded. At the same time that the load was being triggered on the 12v rail, the 5v rail measured a ~20mV drop.
The Transient Load Tests results for the SilverStone SX750 are passing and generally excellent. In today’s testing, the SX750 saw the loaded 12v rail post a peak change of ~300mV, and the loaded 5v rail post a peak change of ~20mV. The unloaded 5v peak change during the 12v load was ~20mV. Those numbers are, in an absolute sense, excellent. In a relative sense, when we consider that this unit is an SFX product, these look a bit better still. That is certainly nothing to sneeze at and, overall, this unit is better than previous SilverStone SFX units (SX700-G and SX700-PT) we have seen. Let’s move on now to see how this unit does in the DC Output Quality aspect of our testing!
