AOC China has announced its latest AGON gaming monitor, the AG274QXM. A variant of the AGON AG274QX model that was announced back in March, AOC’s new “M” revision boasts a 27-inch QHD (2560 x 1440) IPS panel with a Mini LED backlight that comprises 576 local dimming zones for improved contrast ratios and deeper black levels. The monitor supports refresh rates of up to 170 Hz via DisplayPort (up to 140 Hz via HDMI 2.0), a 1 ms GtG response time, VESA DisplayHDR 1000 certification for a peak brightness level of 1,000 nits, and Adaptive Sync/AMD FreeSync for tear-free gameplay. Users will also find four USB Type-A 3.2 ports and one USB Type-B upstream port.
Key Specifications
| Product Code | AG274QXM |
| Screen size (diagonal) | 27″W |
| Viewable size (diagonal) | 68.5cm |
| Screen aspect ratio | 16:9 |
| Panel type | IPS technology |
| Dot pitch | 0.2331(H)x0.2331(V)mm |
| Screen size | 596.736(H)x335.664(V)mm |
| Brightness (typical value) | 550cd/m² (HDR off) 600cd/m² (HDR on) (peak: 1000cd/m²) |
| Contrast (typical value/minimum value) | 1000:1/700:1 |
| Dynamic contrast (typical value) | 80000000:1 |
| Response time | 1ms GtG |
| Viewing angle (horizontal/vertical) (typical value) | 178°/178°(CR>10) |
| scanning frequency | Horizontal: 30k-230kHz(HDMI, USB C) 30k-255kHz(DP) Vertical: 48-144Hz(HDMI, USB C) 48-170Hz(DP) |
| Maximum resolution | 2560×1440@144Hz(HDMI, USB C [1] ) 2560×1440@170Hz [2] (DP) |
| Display color | 1.07 billion [3] [4] |
| Color gamut (typical value) | 100% sRGB (BT.709) coverage rate (based on CIE 1931) 155% sRGB (BT.709) color gamut area (based on CIE 1931) 98% DCI-P3 coverage rate (based on CIE 1976) 116% DCI-P3 color gamut Area (based on CIE 1976) 95% NTSC coverage (based on CIE 1976) 127% NTSC color gamut area (based on CIE 1976) 99% Adobe RGB coverage (based on CIE 1976) 125% Adobe RGB color gamut area (based on CIE 1976) |
| Factory color calibration (average value) | ΔE<2 |
| HDCP function | Yes |
| interface | HDMI2.0(HDR)×2, DP1.4(HDR), USB C(DP Alt), USB3.2 Gen1×4, USB upstream, man-machine controller interface, audio output (headset interface), microphone input, microphone Output |
Sources: AOC, DisplaySpecifications
