Sapphire has officially debuted its new flagship air-cooled Toxic AMD Radeon RX 6900 XT graphics card after teasing it on Facebook. The new card borrows some design traits from the previous NITRO+ series such as a three-fan cooling solution, but it features a new gold/orange motif and ARGB. The Tri-X cooling solution also features a combined memory and VRM cooling module with two heat pipes running underneath, which is said to improve thermal conductivity by 38 percent over the former design. The 7 nm GPU is believed to be a Navi 21 XTXH GPU.
| GPU | AMD Radeonâ„¢ RX 6900 XT Graphics Card 7nm GPU AMD RDNAâ„¢ 2 Architecture |
| Engine Clock | Boost Clock: Up to 2425 MHz Game Clock: Up to 2235 MHz Boost Clock is the maximum frequency achievable on the GPU running bursty workload. Boost clock achievability, frequency, and sustainability will vary based on several factors, including but not limited to: thermal conditions and variation in application and workloads. Game Clock is the expected GPU clock when running typical gaming applications, set to typical TGP(Total Graphics Power). Actual individual game clock results may vary. |
| Stream Processors | 5120 |
| Infinity Cache | 128MB |
| Ray Accelerators | 80 |
| Memory Size/Bus | 16GB GDDR6 |
| Memory Clock | BIOS Default: 16 Gbps Effective |
| Displays | Maximum 4 Displays |
| Resolution | HDMI™: 7680×4320 DisplayPort1.4: 7680×4320 |
| Interface | PCI-Express 4.0 |
| Output | 1x HDMI 3x DisplayPort |
| BIOS Support | Dual UEFI |
| Game Index | 4K |
| Sapphire Features | Dual BIOS Max Boost TriXX Software Switch Premium Digital Power Design Fuse Protection TOXIC Air-Cooled Tri-X Cooling Technology Intelligent Fan Control Precision Fan Control Backplate with ARGB ARGB Fans Two-Ball Bearing Fans Hybrid Fan Blade Wave Fin Design V Shape Fin Design for GPU Cooling Integrated Cooling Module K6.5 Memory Pad TriXX Supported Fan Check Fan Quick Connect TriXX Boost NITRO Glow External RGB LED MB Synchronization |
| AMD Features | AMD RDNA™ 2 Gaming Architecture DirectX® 12 Ultimate Hardware Raytracing 7nm GPU GDDR6 Memory PCI® Express 4.0 Support AMD FreeSync™ Technology DisplayPort™ 1.4 with DSC HDMI™ Video Streaming up to 8K Radeon™ VR Ready Premium AMD FidelityFX Radeon™ Image Sharpening Radeon™ Anti-Lag Radeon™ Software Game Driver Optimizations High Performance 4K Gaming |
| Cooling | TOXIC Air-Cooled Tri-X Cooling Technology Two-Ball Bearing Fans |
| Form Factor | 3 slot, ATX Dimension: 320(L)X 134.85(W)X 58.4 (H)mm |
| Power Consumption | <400W |
| OS | Linux®, Windows® 7*, Windows® 10, and Windows 8.1. 64-bit operating system required *Does not support all features including but not limited to Hardware Raytracing |
| System Requirements | Minimum 850 Watt Power Supply 2 x 8-pin + 1 x 6-pin Power Connector. PCI Express® based PC is required with one X16 lane graphics slot available on the motherboard. Minimum 8GB of system memory. 16GB recommended. |
The graphics card appears to be borrowing the design from the NITRO series, in fact, it seems to be just a new color scheme with the exact same cooler design.
Source: Sapphire (via VideoCardz)
