GIGABYTE has introduced a new, beefy power supply called the AORUS P1200W that’s designed to attract more attention than the average PSU. Beyond the usual benefits of premium power supplies such as a fully modular design, 100 percent Japanese capacitors, and a double ball bearing fan, GIGABYTE’s AORUS P1200W PSU boasts a relatively large digital LCD monitor that can be configured to display the health status of the power supply in real time. The display can also be used to display various types of media, such as text messages, pictures, GIFs, and MP4 videos. GIGABYTE’s AORUS P1200W power supply is 80 PLUS Platinum certified.
Key Features
- Digital LCD monitor
- 80 PLUS Platinum certified
- Fully modular design
- 100% Japanese capacitors
- Compact size design
- 140mm smart double ball bearing fan
- Fan dust removal function
- Single +12V rail
- OVP/OPP/SCP/UVP/OCP/OTP protection
- 10 years warranty (Adjusted according to different regions)
Specifications
Model | GP-AP1200PM |
Type | Intel Form Factor ATX 12V v2.31 |
PFC | Active PFC (>0.9 typical) |
Input Voltage | 100-240 Vac (full range) |
Input Current | 15-7.5A |
Input Frequency | 60-50 Hz |
Output Capacity | 1200W |
Dimension | 150 X 160 x 86mm |
Fan Type | 140mm Double ball bearing Fan |
80 PLUS | Platinum |
Efficiency | 92% at typical load |
MTBF | >100,000 hours |
Protection | OVP/OPP/SCP/UVP/OCPIOTP |
Power Good Signal | 100-500ms |
Hold Up Time | -16ms |
Cable Type | Flat, All black |
Connectors | ATX/MB 20+4 Pin x 1: 610mm* 1 CPU/EPS 4+4 Pin X 2: 650mm 2 PCI-e 6+2 Pin X 10 : 650mm+150mm*4/650mm*2 SATA X 16 : 650mm+150mm+150mm+150mm*4 4 Pin Peripheral x 6+4-Pin floppy X 2 : 600mm+120mm+120mm+150mm*2 |
With the help of engineers’ excellent design capabilities and heat dissipation technology on various hardware products, and the use of higher quality materials, AORUS has reduced the size of a 1200W power supply that is generally designed to be 200 mm long to an amazing 160 mm, so it can be easily installed in any chassis without space constraints.
Source: GIGABYTE
