Thermaltake has launched new memory kits for enthusiasts who have distanced themselves from the traditional black setup.
Comprising eight kits with memory sizes ranging from 16 GB to 64 GB and speeds ranging from 3,600 MHz to 4,600 MHz, Thermaltake’s new series of TOUGHRAM XG RGB DDR4 memory features a white-colored chassis and cooling components complemented by an X-shaped light bar with 16 addressable LEDs. Other highlights include a 10-layer PCB with 2 oz. copper inner layer, tightly screened ICs, an aluminum heat spreader, and limited lifetime warranty.
From Thermaltake’s press release:
Being compatible with the latest AMD and Intel motherboards, the White TOUGHRAM XG RGB series has been through rigorous tests to select tightly-screened ICs, designed with a ten-layer PCB, constructed with 10μ gold fingers and 2oz copper inner layers to ensure high and stable performance. The White TOUGHRAM XG RGB series also carries an exclusive style from its appearance thanks to its special design, there are 2 different colors, detailing an aluminum trim with a chrome stripe in the middle which makes the TOUGHRAM XG RGB series stand out from your everyday RAM modules.
Featuring 16 high-lumen addressable LEDs, the White TOUGHRAM XG RGB series is equipped with a unique X-shape light bar that can control 8 lighting zones. This aims at delivering a more vivid and customized lighting experience, and it’s supported by TT RGB PLUS and NeonMaker Light Editing Software, at the same time it can be synchronized with other compatible software such as TT AI Voice Control, Amazon Alexa, and motherboard RGB software, to let users create their very own lighting show.
A list of the new Thermaltake TOUGHRAM XG RGB DDR4 White series and their respective pages:
- 3600MHz 16GB Kit (2x8GB)
- 4000MHz 16GB Kit (2x8GB)
- 4400MHz 16GB Kit (2x8GB)
- 4600MHz 16GB Kit (2x8GB)
- 3600MHz 32GB Kit (2x16GB)
- 4000MHz 32GB Kit (2x16GB)
- 3600MHz 64GB Kit (2x32GB)
- 4000MHz 64GB Kit (2x32GB)
Source: Thermaltake
