4K Ray Tracing and DLSS Performance
Finally, we’ll look at the impact of Ray Tracing and DLSS at 4K to see if the EVGA GeForce RTX 3080 Ti FTW3 ULTRA GAMING can pull off a decent Ray Tracing experience at 1440p. For each game, we are using the game benchmark included with the game and reporting the average frames per second.
Far Cry 6
In Far Cry 6, the EVGA GeForce RTX 3080 Ti FTW3 ULTRA GAMING slinked out ahead of the ASUS TUF RX 6800 XT and EVGA GEFORCE RTX 3080 12GB FTW3 ULTRA GAMING at 65 FPS. Overclocking the EVGA GeForce RTX 3080 Ti FTW3 ULTRA GAMING brought it up to 72 FPS. Across the board, FSR provided a boost of about 20 FPS.
You may have noticed that we did not mention the EVGA GeForce RTX 3080 10GB FTW3 ULTRA GAMING stellar performance at 7 FPS while kicking an empty trash can and muttering about how embarrassing it was. This is a prime example of what happens to performance when there’s not enough VRAM to go around.
Watch Dogs: Legion
In Watch Dogs Legion, the EVGA GEFORCE RTX 3080 TI FTW3 ULTRA GAMING achieved 34 frames per second, which is 13 frames per second faster than the ASUS TUF RX 6800 XT and 2 frames per second faster than the EVGA GEFORCE RTX 3080 12GB FTW3 ULTRA GAMING. Overclocking the EVGA GEFORCE RTX 3080 TI FTW3 ULTRA GAMING didn’t make a difference to its Racy Tracing performance unless 3 FPS is a difference to you. You don’t want to play Watch Dogs: Legion with Ray Tracing on any of these cards.
Next, we tried out DLSS set to “Quality” mode and as you can see in the chart, it boosted the overall performance of the NVIDIA cards by a significant margin, to the extent that it makes for a great gaming experience to have both Ray Tracing and DLSS: Quality enabled. DLSS made Ray Tracing very playable at this resolution.
Again, we see the EVGA GeForce RTX 3080 10GB FTW3 ULTRA GAMING hitting a VRAM wall like it painted it on the side of the mountain a-la Wile E. Coyote and its subsequent splat into the mountainside.
Metro Exodus
In Metro Exodus, the EVGA GEFORCE RTX 3080 TI FTW3 ULTRA GAMING cranked out 41 frames per second, which is 14.2 frames per second faster than the ASUS TUF RX 6800 XT and 2.4FPS faster than the EVGA GEFORCE RTX 3080 12GB FTW3 ULTRA GAMING. Overclocking the EVGA GEFORCE RTX 3080 TI FTW3 ULTRA GAMING notched an additional 2.9 frames per second to the tally. Whether Metro Exodus is playable on these cards is really the dealer’s choice as there will be some areas that have less than ideal performance but most of the game should be just fine.
Next, we tried out DLSS turned on and as you can see in the chart, it boosted the overall performance of the NVIDIA cards by about 15-20 frames per second, to the extent that it makes for a great gaming experience to have both Ray Tracing and DLSS: Quality enabled.
Shadow of the Tomb Raider
In Shadow of the Tomb Raider, the EVGA GeForce RTX 3080 Ti FTW3 ULTRA GAMING put up 61 FPS, which bested the EVGA GeForce RTX 3080 10GB FTW3 ULTRA GAMING and ASUS TUF RX 6800 XT and the EVGA GEFORCE RTX 3080 12GB FTW3 ULTRA GAMING. Overclocking the EVGA GeForce RTX 3080 Ti FTW3 ULTRA GAMING added to its lead at 65 FPS.
Dirt 5
In Dirt 5, the EVGA GeForce RTX 3080 Ti FTW3 ULTRA GAMING achieved 82.2 FPS which bested the rest of the competition. Overclocking the EVGA GeForce RTX 3080 12GB FTW3 added 7.9% to the top at 88.7 FPS.
Discussion (3 replies)
Join Discussion →Great review! I have this card in my main PC, and it's been great so far. I actually downgraded from my Aorus Master 3090 to this card and seen zero performance differences. To compare your findings on the temperatures my card never goes over 70C while gaming, so it may be the card you tested with possibly. That is my only real complaint with this card is that it runs hotter than the Aorus 3090 I had, but not enough for me to regret my purchase.
I've got the 3090 version of one of these in my 4930K rig. The fans handle it but they do seem to ramp up to max more than other 3090s I've used. Still a great card though, just seems to work a little harder to keep the same temps.
I agree that the fans do ramp up quite a bit.
