AMD Radeon RX 6750 XT Only 2% Percent Faster than Radeon RX 6700 XT: GFXBench
Image: AMD
AMD users may want to temper their expectations when it comes to the level of performance improvement provided by red team’s upcoming trio of refreshed Radeon RX 6000 Series graphics cards. GFXBench has posted the first benchmarks for one of the new models, the Radeon RX 6750 XT, and the numbers in the offscreen tests indicate that the GPU may only be around 2% faster than the Radeon RX 6700 XT.
Image: GFXBench
AMD Radeon RX 6750XT shows up on GFXBench website, 2% faster than RX 6700XT (VideoCardz)
The Radeon RX 6750XT is the upcoming refresh of RX 6700XT with faster memory and higher clock speeds. This is the Navi 22 GPU based upper-midrange model with 12GB GDDR6, now likely clocked at 18 Gbps. Higher memory frequency and rumored increase of board power, are expected to provide a noticeable, but not significant performance uplift. It might be just enough to tackle the upcoming Intel Arc desktop cards, though.
The RX 6750XT off-screen performance in Aztec Ruins High Tier test is 366.5 FPS, which is just 2% higher than RX 6700 running in the same graphics API (DirectX).
AMD is expected to launch the Radeon RX 6750 XT on May 10. It will be joined the Radeon RX 6950 XT and Radeon RX 6650 XT, and all of them will feature 18 Gbps memory, a 2 Gbps improvement over their predecessors. The new Radeon RX 6950 XT flagship is also rumored to feature a 50-watt higher TBP than the Radeon RX 6900.
