Philips UK Launches 34-Inch Curved 21:9 Monitor with Webcam
Image: Philips
Philips UK has launched the 34E1C5600HE, a 34-inch monitor with 5 MP webcam that’s Windows Hello certified. Its curved (1500R) VA panel offers a 3440×1440 resolution, 100 Hz refresh rate, adaptive sync, 4 ms GtG response time, and peak brightness of 300 cd/m². Connectivity includes 1x HDMI 2.0, 1x DP 1.2, and 1 x USB-C that supports DisplayPort Alt Mode and Power Delivery. The 34E1C5600HE will be available in the UK and Europe beginning in July for £479.99 and €619, respectively.
Picture/Display
• LCD panel type: VA LCD
• Backlight type: W-LED system
• Panel Size: 34 inch / 86.36 cm
• Display Screen Coating: Anti-Glare, 3H, Haze 25%
• Effective viewing area: 797.22 (H) x 333.72 (V) – at a 1500R curvature*
• Aspect ratio: 21:9
• Maximum resolution: 3440 x 1440 @ 100 Hz*
• Pixel Density: 109.68 PPI
• Response time (typical): 4 ms (Grey to Grey)*
• MPRT: 1 ms
• Brightness: 300 cd/m²
• Contrast ratio (typical): 3000:1
• SmartContrast: Mega Infinity DCR
• Pixel pitch: 0.23175 x 0.23175 mm
• Viewing angle: 178º (H)/178º (V), @ C/R > 10
• Flicker-free
• Picture enhancement: SmartImage game
• Colour gamut (typical): NTSC 99.25%, sRGB 123.24%
• Display colours: 16.7 M
• Scanning Frequency: 30–160 kHz (H)/48–100 Hz(V)
• LowBlue Mode
• EasyRead
• sRGB
• Adaptive sync
Connectivity
• Signal Input: HDMI 2.0 x 1, DisplayPort 1.2 x 1, USB-C x 1 (DisplayPort Alt mode, data and Power Delivery)
• HDCP: HDCP 1.4 (HDMI/DisplayPort/USB-C), HDCP 2.2 (HDMI/DisplayPort/USB-C)
• USB Hub: USB 3.2 Gen 1, USB-A downstream x 4 (with 1 fast charge B.C 1.2)
• Sync Input: Separate Sync
• Audio (In/Out): Audio out
Power Delivery
• Version: USB PD version 3.0
• Max power delivery: USB-C: Up to 65 W (5 V/3 A, 7 V/3 A, 9 V/3 A, 10 V/3 A, 12 V/3 A, 15 V/3 A, 20 V/3.25 A)
Convenience
• Built-in Speakers: 5 W x 2
• Built-in webcam: 5 MP Hello webcam
• Noise cancellation
• MultiView: PIP/PBP mode, 2 x devices
• User convenience: Power On/Off, Menu, Volume, Input, SmartImage Game
• OSD Languages: Brazil Portuguese, Czech, Dutch, English, Finnish, French, German, Greek, Hungarian, Italian, Japanese, Korean, Polish, Portuguese, Russian, Simplified Chinese, Spanish, Swedish, Traditional Chinese, Turkish, Ukrainian
• Other convenience: Kensington lock, VESA mount (100 x 100 mm)
• Plug and Play Compatibility: DDC/CI, Mac OS X, sRGB, Windows 10 / 8.1 / 8 / 7
Stand
• Height adjustment: 130 mm
• Tilt: -5/20 degree
Power
• On mode: 57.0 W (typ.)
• Standby mode: 0.5 W (typ.)
• Off mode: 0.3 W (typ.)
• Energy Label Class: G
• Power LED indicator: Operation – White, Standby mode – White (flashing)
• Power supply: Internal, 100–240 VAC, 50–60 Hz
Dimensions
• Product with stand (mm): 808 x 557 x 281 mm
• Product without stand (mm): 808 x 381 x 111 mm
• Packaging in mm (W x H x D): 980 x 519 x 226 mm
Weight
• Product with stand (kg): 9.29 kg
• Product without stand (kg): 7.16 kg
• Product with packaging (kg): 12.43 kg
Sources: Philips
