Overclocked GeForce RTX 3090 Ti vs Overclocked Radeon RX 6950 XT
Test Setup
Please read our GPU Test Bench and Benchmarking Refresher for an explanation of our test system, procedures, and goals.  Note that we now have a Ryzen 7 5800X in the system.  More information on our GPU testing can be found here.  Check out our KIT page where you can see all the components in our test system configuration for reviewing video cards.
System Setup Table
System Setup
We are using the motherboard’s current default BIOS settings on the latest official release BIOS.  We have enabled PCI-Express Resizable BAR in the motherboard BIOS.  This means we are utilizing Resizable BAR on NVIDIA GPUs and AMD Smart Access Memory on AMD GPUs in all of our testing.  We have enabled DOCP in the BIOS for the memory.
We are using a fresh install of Windows 11 Pro with the latest Windows Updates, and drivers installed including the latest chipset drivers from AMD.  We are using the “Best Performance” power profile in Windows Settings.  VBS is DISABLED and Game Mode is ENABLED.
Discussion (5 replies)
S
Great article, but I'm picky. I'd like to see RT 4k benches with DLSS/FSR. I'm willing to bet the 3090Ti can get close to 60fps or even better.
Probably, but with respect to the title of the article - you have two cards, one costs almost twice what the other does (at least at the time of printing, the price has since been adjusted, it's still 50% higher after the price cut). Thinking about it in those terms, and the numbers suddenly look a lot different.
Brent_Justice
Brent_Justice 👍 1
And that is why I ended my review with this final paragraph under Final Points.
When it comes down to raw performance, with both video cards performing very well when overclocked the key factor will come down to what is available, and how much they will cost. Right now prices are falling, and you can actually buy these video cards at MSRP, or even below. Since that is the case, whichever one you can find for the cheaper price is probably your best bet and best value for right now, and with the raw MSRP difference between them, it could end up being the Radeon RX 6950 XT. It offers amazing raw performance for the price compared to the higher MSRP on the RTX 3090 Ti and has the most overclocking headroom.
S
Stoly 👍 1
As of today the RX 6950 XT is about $1,100 and the RTX 3090 Ti around $1,500. It's up to you to justify the price for the extra RT performance. But then again $1500/$1100 seems like a steal when you consider these cards were going for almost twice the price just a few days ago.
S
Stoly 👍 1
BTW where are the non-oc results for comparison? Yes I'm picky... (and lazy as I know I can just look at the cards reviews) :LOL: :p
