NZXT has launched its line of Canvas gaming monitors beginning with 27-inch flat and 32-inch curved QHD resolution displays. Each display features a panel with a 165 Hz refresh rate, HDR10 with an sRGB 99% color gamut, and a response time of 1 ms. They both have anti-glare and flicker-free technology for optimal viewing while minimizing eye strain. Adaptive sync technology includes AMD Freesync and is NVIDIA G-Sync compatible. The NZXT Canvas 32Q features an IPS panel with a 1500R curvature while the Canvas 27Q is a flat VA panel with a stand that allows horizontal or vertical positioning.
NZXT allows customers to mix-match the black/white colors between the stand and its panel for either model and also offers single ($99.99) or dual ($169.99) monitor arms on its sales page. Both monitors are also compatible with NZXT’s CAM PC monitoring software.
Canvas 27Q Specifications
Price: $319.99
Panel Type:IPS
Resolution:QHD (2560×1440)
Refresh Rate:165Hz
Bezel Type:Borderless
Form Factor:Flat
Aspect Ratio:16:9
Color Gamut:sRGB 99%
HDR:HDR 10
Adaptive Sync:FreeSync Premium, G-Sync Compatible
VESA Compatibility:100x100mm
Display Surface:Anti-Glare
Flicker Free:Yes
Low Blue Light:YesDisplay Colors:16.7M
Response Time:1ms
Brightness:300cd/m²
Viewing Angle:178° / 178° (Typ)
Active Display Area:596.74 (H) x 335.66 (V)
Contrast Ratio:1000:1Power Consumption:DC output 65.56W Max
Power Consumption – Backlight:DC output 25W Max
Power Consumption – System (including O.C):DC output 34W Max
Power Saving Mode:< 0.5W
Power Off Mode:< 0.3W
Power Type:External Adapter: DC output 65W Max
Voltage:Input: 100~240VHDMI:2.0 x2
DP:1.2 x1
USB Type A:3.0 x2
USB C / DP Alt:x1
USB B:3.0 x1
Audio:3.5mm x1Software Support:NZXT CAM Software
Product Dimension (with stand):615mm x 526.6mm x 219.7mm
Product Dimension (without stand):615mm x 367mm x 69.8mm
Net Weight (kg), Panel Only:3.7kg (8.15lb)
Net Weight, Stand Only:2.6kg (5.73lb)
Warranty:3 years
Canvas 32Q Curved Specifications
Price: $379.99
Panel Type:VA
Refresh Rate:165Hz
Form Factor:Curved
Radius of Curvature:R1500
Aspect Ratio:16:9
HDR:HDR 10
Flicker Free:Yes
Response Time:1ms
Brightness:300cd/m²
Active Display Area:697.344 (H) x 392.256 (V)
Contrast Ratio:1000:1Power Consumption:DC output 64.2W Max
Power Consumption – Backlight:DC output 29.4W Max
Power Consumption – System (including O.C):DC output 34.8W Max
Power Type:External Adapter: DC output 90W Max
DP:1.2 x1
USB Type A:3.0 x2
USB C / DP Alt:x1
USB B:3.0 x1
Product Dimension (with stand):710.5mm x 605.63mm x 265.17mm
Product Dimension (without stand):710.5mm x 423.27mm x 112.02mm
Net Weight (kg), Panel Only:5.45kg (12lb)
Net Weight, Stand Only:3kg (6.61lb)
Warranty:3 years
0 comments
