CORSAIR VENGEANCE DDR5 32GB 6000MHz C36 Memory Kit Review
CORSAIR VENGEANCE DDR5 32GB (2x16GB) 6000MHz Memory 4k RGB installed in system
Today we reviewed the CORSAIR VENGEANCE DDR5 32GB (2x16GB) 6000MHz C36 Memory Kit and compared it to stock JEDEC timings and the best overclock we could get out of it. The kit includes 2x16GB DDR5-6000MHz sticks with an XMP profile set to 36-36-36-76 timings at 1.35V.
The memory kit features individually controllable RGB lighting to synch it to your CORSAIR branded tricked-out rig with iCUE.
From an overall performance perspective, the CORSAIR VENGEANCE DDR5 32GB (2x16GB) 6000MHz Memory found a good balance between overall bandwidth and latency. In many of our tests, the stock XMP configuration was faster than our manual overclock and in almost all cases, faster than the JEDEC stock speeds of 4800MHz.
Pulling it all together, the CORSAIR VENGEANCE DDR5 32GB (2x16GB) 6000MHz C36 Memory is offered by CORSAIR for $249.99, which is less than the Patriot Viper 6200MHz memory that we reviewed last month and trades blows with it across the suite of benchmarks. It was completely stable at its XMP configured speeds and got the job done. For that, if you’re looking for memory for your DDR5 rig, the CORSAIR VENGEANCE DDR5 32GB (2x16GB) 6000MHz Memory should certainly be on your shortlist. With DDR5’s usefulness increasing, and with Intel systems having it now, and AMD systems in the future, and prices falling on DDR5 it is time to keep an eye on solid DDR5 RAM like this.
