Some GeForce RTX 4090 Graphics Cards Are Recommending a 1,200-Watt Power Supply
Image: Palit
Enthusiasts who plan to upgrade to NVIDIA’s new flagship gaming GPU may need a stronger-than-expected power supply based on a roundup of wattage requirements that’s been shared online. Palit, for one, has recommended that its GeForce RTX 4090 GameRock OC, a custom graphics card that lists a boost clock of 2,610 MHz among its specifications, be paired with a 1,200-watt power supply. This is quite a bit higher than the 850-watt minimum system power specification that NVIDIA has listed for its GeForce RTX 4090 Founders Edition.
NVIDIA GeForce RTX 4090 PSU Wattage Requirements
ModelsTarget Board PowerMinimum PSU Wattage
Asus RTX 4090 ROG Strix OCUnknown1000W
Aorus RTX 4090 MasterUnknown1000W
MSI RTX 4090 Suprim X, Suprim Liquid XUnknown850W
PNY RTX 4090 Verto Epic-X450W850W
Zotac RTX 4090 AMP Extreme, Trinity450W1000W
Galax RTX 4090 SG, STUnknown850W
All Colorful RTX 4090 ModelsUnknownUnknown
Inno3D RTX 4090 X3 OC iChill BlackUnknown850W
Palit RTX 4090 GameRock OC450W1200W
Gainward RTX 4090 Phantom GSUnknownUnknown
From a Tom’s Hardware report:
[…] the star of the show — or perhaps the supernova in this case — is Palit, with its RTX 4090 GameRock graphics card recommending a whopping 1200W PSU. That’s by far the most demanding spec we’ve ever see from any graphics card company so far, though quad-SLI GTX 980 Ti back in the day could use more power. That’s obviously with four GPUs instead of just one, however.
Palit neglected to share its reasoning behind the monstrous 1200W PSU recommendation, but it could be due to a number of reasons. It’s possible that with a test setup that includes a power hungry CPU like a Core i9-12900K, heavily overclocked, it might feel 1200W is warranted. Or maybe it’s based on what you might see from extreme cards like a Galax Hall of Fame (HOF). Except Palit also lists a TBP (Total Board Power) of just 450W on its cards.
Palit’s GeForce RTX 4090 GameRock OC will presumably be available alongside many other custom GeForce RTX 4090 models when the series officially launches on October 12. Additional Ada Lovelace options will arrive in the form of the GeForce RTX 4080 (16 GB) and GeForce RTX 4080 (12 GB) in November.
