SAPPHIRE Launches NITRO+ AMD Radeon RX 7900 Vapor-X Series and PULSE AMD Radeon RX 7900 Series Graphics Cards
Image: SAPPHIRE
SAPPHIRE has launched its first Radeon RX 7900 Series graphics cards in the form of the PULSE AMD Radeon RX 7900 Series and NITRO+ AMD Radeon RX 7900 Vapor-X Series, the latter of which comprises Radeon RX 7900 XT and Radeon RX 7900 XTX models that offer breakthrough performance and incredible clock speeds for both gamers and creators at 4K resolutions and beyond, according to the leading manufacturer and global supplier of innovative graphics and mainboard products.
SAPPHIRE NITRO+ AMD Radeon RX 7900 Series
Image: SAPPHIRE
NITRO+ AMD Radeon RX 7900 XTX Vapor-X, 24GB, AMD RDNA 3
  • GPU: Boost Clock: Up to 2680 MHz
  • GPU: Game Clock: Up to 2510 MHz
  • Memory: 24GB/384 bit DDR6. 20 Gbps Effective
  • Stream Processors: 6144
  • RDNA 3 Architecture
  • Ray Accelerator: 96
NITRO+ AMD Radeon RX 7900 XT Vapor-X, 20GB, AMD RDNA 3
  • GPU: Boost Clock: Up to 2560 MHz
  • GPU: Game Clock: Up to 2220 MHz
  • Memory: 20GB/320 bit DDR6. 20 Gbps Effective
  • Stream Processors: 5376
  • Ray Accelerator: 84
Key Features
  • NITRO+ AMD Radeon RX 7900 Series Graphics Cards deliver ultra-high frame rates at 4K gaming performance with the standout iconic Vapor-X Cooling
  • Groundbreaking AMD RDNA 3 gaming architecture with new and favourite technologies including AMD Radiance Display Engine, AMD FidelityFX Super Resolution and AMD Radeon Super Resolution advanced upscaling technologies
  • Introducing the SAPPHIRE PANTHEON Suite of permanent NITRO+ features
  • Maximum Overclocking Potential
  • Factory-overclocked performance and new, innovative custom cooling solutions
  • Up to 2680 MHz Boost Clock and 2510 MHz Game Clock
  • Unique features and fine-tuned performance to craft a fast and stable gaming experience
  • Performance increase in popular games with TriXX Boost
At the core of the NITRO+ AMD Radeon RX 7900 Series is a suite of premium features called SAPPHIRE PANTHEON, according to the company:
SAPPHIRE PANTHEON guarantees supreme cooling technology and other distinct features exclusive to NITRO+ graphics cards. Each NITRO+ iconic feature stands as strong and permanent as the pillars of the PANTHEON. Every NITRO+ Graphics Card guarantees the presence of the stable, reliable and innovative SAPPHIRE PANTHEON suite of features.
Experience a new standard for ultra-enthusiast class gaming performance with the NITRO+ AMD Radeon RX 7900 Graphics Card with Vapor-X technology. The NITRO+ AMD Radeon RX 7900 XTX Vapor-X Graphics Card headlines with 6144 stream processors running with two clock settings, including a Boost Clock of up to 2680 MHz and a Game Clock of up to 2510 MHz. It also offers 24GB of high-speed GDDR6 memory clocked at 20 Gbps with 96MB of second generation AMD Infinity Cache technology. The NITRO+ AMD Radeon RX 7900 XT Vapor-X Graphics Card features a GPU with 84 Compute Units and 5376 stream processors, a Boost Clock of up to 2560 MHz and a Game Clock of up to 2220 MHz. Enjoy breakthrough performance on the NITRO+ AMD Radeon RX 7900 XTX Vapor-X and XT respectively with 24GB and 20GB of GDDR6 high-speed memory clocked at up to 20 Gbps with 96MB and 80MB of Infinity Cache technology. The graphics card has support for up to 4 output ports including 2x HDMI 2.1 and 2x Display Port 2.1 ports with DSC outputs to support the latest monitors on the market.
SAPPHIRE’s Vapor-X Cooling design, which the company is describing as iconic, is headlined by a Vapor Chamber that is mounted in contact with the surface of the GPU and GDDR6 memory. It’s said to work more efficiently than a copper heat sink.
SAPPHIRE also noted that its NITRO+ AMD Radeon RX 7900 Series features a digital power design that enables 28% more power delivery for the GPU versus AMD’s reference design, enabling maximum overclocking potential.
Image: SAPPHIRE
Joining the NITRO AMD Radeon RX 7900 Series is the PULSE AMD Radeon RX 7900 Series, which SAPPHIRE says offers great gaming performance at excellent value.
PULSE AMD Radeon RX 7900 XTX Graphics Card, 24GB, AMD RDNA 3 Architecture
  • GPU: Boost Clock: Up to 2525 MHz
  • GPU: Game Clock: Up to 2330 MHz
PULSE AMD Radeon RX 7900 XT Graphics Card, 20GB, AMD RDNA 3 Architecture
  • GPU: Boost Clock: Up to 2450 MHz
  • GPU: Game Clock: Up to 2075 MHz
The PULSE AMD Radeon RX 7900 XTX Graphics Card headlines with 96 Compute units and 6144 stream processors running with a Boost Clock of up to 2525 MHz and a Game Clock of up to 2330 MHz. The PULSE AMD Radeon RX 7900 XT features 84 Compute Units with 5376 stream processors, a Boost Clock of up to 2450 MHz and a Game Clock of up to 2075 MHz. Visualize the latest 24GB and 20GB respectively of GDDR6 high-speed memory clocked at 20 Gbps Effective with 96MB and 80MB respectively of Infinity Cache. The graphics card supports up to 4 output ports including 2x HDMI 2.1 and 2x Display Port 2.1 ports with DSC outputs to align with the latest monitors on the market.
The SAPPHIRE PULSE AMD Radeon RX 7900 Series Graphics Cards run on SAPPHIRE’s distinguished Tri-X Cooling Technology which work in tandem with the Intelligent Fan Control and Precision Fan Control features to keep temperatures low and fan noise low. Stability and reliability are key pillars of the PULSE AMD Radeon RX 7900 Series Graphics Cards. The High TG Copper PCB design enables stable and reliable performance resulting in a low temperature and low noise PCB component. The crucial Fuse Protection feature is built into the circuit of the external PCIe® power connector to keep the components safe. As part of SAPPHIRE’s motto of long-lasting components, Dual-Ball Bearing Fans are fitted to increase the lifespan of the Graphics Cards.
SAPPHIRE has confirmed that its NITRO+ AMD Radeon RX 7900 Series Vapor-X and PULSE AMD Radeon RX 7900 Series graphics cards are shipping now and will be available from select SAPPHIRE e-tailers and retailers worldwide.
SAPPHIRE did not share pricing details in its announcement.
