ASRock has announced the Radeon RX 7900 XTX Taichi White 24GB OC Graphics Card. According to a press release from the leading global motherboard, graphics card, and mini PC manufacturer, this is the company’s first white graphics card. The Radeon RX 7900 XTX Taichi White 24GB OC Graphics Card features a boost clock of up to 2,680 MHz, which is higher than the reference model’s 2,500 MHz.
ASRock Radeon RX 7900 XTX Taichi White 24GB OC Features
- Clock: GPU / Memory
- Boost Clock: Up to 2680 MHz / 20 Gbps
- Game Clock: 2510 MHz / 20 Gbps
- Key Specifications
- AMD Radeon RX 7900 XTX GPU
- 24GB GDDR6 on 384-Bit Memory Bus
- 96 AMD RDNA 3 Compute Units (With Rt+Ai Accelerators)
- 96MB AMD Infinity Cache Technology
- PCI Express 4.0 Support
- 3 x 8-pin Power Connectors
- 3 x DisplayPort 2.1 / 1 x HDMI 2.1
- Key Features
- Polychrome SYNC
- Taichi 3X Cooling System
- ARGB Backplate
- Reinforced Metal Frame
- Dual BIOS
- 22 Power Phase Design
- 110/100/110mm Striped Ring Fans
From an ASRock press release:
ASRock, the leading global motherboard, graphics card and mini PC manufacturer, today announced its first white graphics card, the ASRock Radeon RX 7900 XTX Taichi White 24GB OC. This graphics card is powered by the high-end AMD Radeon RX 7900 XTX GPU and features 24GB GDDR6 memory, as well as ASRock’s latest technologies. With outstanding performance and an exquisite white aesthetic, this graphics card is perfect for hardcore gamers and professional creators looking to build a high-performance, white-themed PC.
The new graphics card is built on the groundbreaking AMD RDNA 3 architecture with chiplet technology. AMD RDNA 3 architecture delivers up to 54% more performance-per-watt than AMD RDNA 2 , features the world’s fastest interconnect linking the graphics and memory system chiplets at up to 5.3 TB/s , and offers up to 96 new unified compute units and second-generation AMD Infinity Cache technology. It also delivers increased AI performance and architected compute units with second-generation raytracing technology that provides higher raytracing architectural performance in select titles versus a prior generation AMD graphics card with AMD RDNA 2 architecture.
The graphics card’s surface features a pearlescent white coating that provides an exceptional visual and tactile experience. The metal frame and backplate are also coated with the same treatment, ensuring a unified color scheme and experience throughout the whole product. With its striking aesthetics, the graphics card is sure to become a focal point of any white-themed PC.
