Cooler Master MASTERAIR MA824 Stealth CPU Cooler Review
Sound Level Testing
100% Fans
Cooler Master MASTERAIR MA824 STEALTH max rpm sound testing
At maximum fan levels, the MASTERAIR MA624 Stealth be quiet! Dark Rock Pro 4 was the quietest (40.7 and 40.9 dB(a) respectively) while the Cooler Master MASTERAIR MA824 STEALTH featured a 47.8 dB(A) sound level and the Iceberg Thermal IceSLEET X7 Dual hit 54.1 dB(A)! From a subjective perspective, the Cooler Master MASTERAIR MA824 STEALTH was rather unremarkable from a noise contribution to the room perspective, but certainly louder than the quieter units.
Keep in mind that maximum fan speed varies between the units in this test – the Cooler Master MASTERAIR MA824 STEALTH topped out at 1900 and 1550 RPM, the Iceberg Thermal IceSLEET X7 Dual topped out at 1600 RPM, the be quiet! Dark Rock Pro 4 has the lowest max fan rpm at 1500 RPM and the Cooler Master MASTERAIR MA624 STEALTH tipped in just under 1500 RPM.
1500 RPM Fans
Cooler Master MASTERAIR MA824 STEALTH 1500 rpm sound testing
Dropping down to 1500 RPM, the field did not change much as most units were close to their maximum fan speeds in the first test. The Cooler Master MASTERAIR MA824 STEALTH shed 0.9 dB(A) but no changes in positions occurred.
1000 RPM Fans
Cooler Master MASTERAIR MA824 STEALTH 1000 rpm sound testing
When we lowered the fans down to 1000 RPM, the Cooler Master MASTERAIR MA824 STEALTH, be quiet Dark Rock Pro 4, and MASTERAIR MA624 STEALTH tied for first at 38.7 dB(A). The Iceberg Thermal IceSLEET X7 Dual was off in the weeds at 44.1 dB(A). At this point, the noise from all of the coolers sounded like it merged with the background noise for everyone except the IceSLEET X7 Dual.
600 RPM Fans
Cooler Master MASTERAIR MA824 STEALTH 600 rpm sound testing
Lowering the fans to 600 RPM saw the Cooler Master MASTERAIR MA824 STEALTH take the lead at 35.8 dB(A), just in front of the be quiet! Dark Rock Pro 4 at 37.4 dB(A). The MASTERAIR MA624 STEALTH took third at 38.7 dB(A) and the Iceberg Thermal IceSLEET X7 Dual continued to trail at 39.9 dB(A). At this point, there really is not a subjective difference between the sound output of all of the units.
With that said, let’s move on and recap all of this for you today!
Cooling Performance
Installation Effort
Sound Level
7
Cooler Master MASTERAIR MA824 STEALTH a big yet stealthy CPU cooler that utilizes 8 heat pipes and a pair of Mobius fans to keep your CPU cool. In our testing, we found that it outperformed every air cooler that we have tested to date and did so without making much noise.
