Thermaltake Launches the TOUGHAIR 710 Black CPU Cooler Featuring a Dual-Tower Design with Two 140 mm Fans
Image: Thermaltake
PC builders looking to avoid RGB or liquid cooling have another option as Thermaltake launches the TOUGHAIR 710 Black CPU cooler. This beefy-looking CPU cooler features a dual tower design that is paired with 2x 140mm fans which can provide up to 81.96 CFM airflow that provides a static pressure of 1.81 mm-H2O while keeping things relatively quiet at 23.9 dB-A. The heatsink has a copper base which is coated with an anti-corrosive nickel plating and has seven copper heat pipes. The fan position can also be adjusted to accommodate various different types of memory modules as well.
As Thermaltake launches the TOUGHAIR 710 Black CPU cooler the manufacturer emphasizes its all-black, RGB-less design for all of the cooler’s components. The TOUGHAIR 710 Black CPU cooler is available via Thermaltake’s official US store page for $89.99 and is compatible with nearly all modern AMD/Intel CPUs, including the latest AM5/1700 processors.
Press Release (via official page):
Thermaltake, the leading PC DIY premium brand for Case, Power, Cooling, Gaming peripherals, and enthusiast Memory solutions, is delighted to release the TOUGHAIR 710 Black CPU Cooler, a CPU air cooler designed for the toned-down black aesthetics. The TOUGHAIR 710 Black is a new edition to the TOUGHAIR series and features a Dual-Tower Dual Fan Design, providing superior cooling performance for the latest Intel and AMD CPUs. Now this new-colored TOUGHAIR 710 Black is worldwide available for purchase!
If you are a non-RGB lover and want to build a low-profile but eye-catching PC, look closer to the TOUGHAIR 710 Black. The TOUGHAIR 710 Black is inspired by the shadows and is composed entirely of black components, increasing a sense of mystery and nobleness. Designed for high-performance CPUs, the TOUGHAIR 710 Black comes with the Dual-Tower Dual Fan Design, doubling everything to achieve exceptional cooling performance. To fit all main-stream CPUs, the TOUGHAIR 710 Black is compatible with various Intel and AMD sockets, including the latest Intel 1700 and AM5.
The TOUGHAIR 710 Black keeps the classic asymmetric fin structure of the TOUGHAIR Series and extends the fin stack for a larger heat dissipation area, offering an effective thermal solution. Besides that, the two 140mm fans of the TOUGHAIR 710 leverage the design concept of the TOUGHFAN 14, striking an ideal balance between maximizing performance and minimizing noise. These fans possess an airflow of 81.96 CFM and a static pressure of 1.81 mm-H2O while keeping the noise level at 23.9 dB-A. Additionally, you can easily adjust the fan position to fit the memory height up to 48mm, bringing more flexibility while creating a build. To ensure the TOUGHAIR 710 Black’s cooling performance, it’s built with a copper base with anti-corrosive nickel plating, connecting with seven black Ø6mm U-shape copper heat pipes running through the fin towers, maximizing heat distribution from the heat source.
The TOUGHAIR 710 Black CPU Cooler features a Dual-Tower Dual Fan Design, allowing full support for the high-end CPU with its advanced thermal performance. Its black style conveys low-profile aesthetics, making it a perfect choice for an all-black PC setup!
Features of the TOUGHAIR 710 Black CPU Cooler:
Keep to the Shadows
If you like the classical vibe without RGB, look closer! The hint of color within the shadow is our TOUGHAIR 710 Black, with a new color palette for you to choose from. Pairing with all black color components, you can build a toned-down look that sure to draw everyone’s attention.
Dual-Tower Dual Fan
TOUGHAIR 710 Black is designed for the latest Intel and AMD CPUs, which needs the best possible cooling solution, so we doubled everything and came up with the Dual-Tower Dual Fan Design; it allows the two 140mm fans to push air cooling performance even further, exceeding all previous TOUGHAIR series models.
Lower Noise but More Powerful
TOUGHAIR 710 Black leverages the TOUGHFAN 14 design, so the fan can provide an airflow of 81.96 CFM and a static pressure of 1.81 mm-H2O while keeping the noise level at 23.9 dB-A. So you won’t have to choose between cooling power and acoustics.
Larger Heat Dissipation Area
We have also extended the fin stack so there’s more heat dissipation area to ensure the best cooling result. Along with the significant asymmetric fin structure of the TOUGHAIR Series, no doubt that if you’re looking for a boost on your air cooler, TOUGHAIR 710 Black won’t let you down.
The Ultimate Cooling Solution
TOUGHAIR 710 Black features a copper base with anti-corrosive nickel plating that covers all seven black Ø6mm U-shape copper heat pipes, resulting in even heat distribution from the heat source, providing exceptional heat dissipation even with high-performance CPUs.
Flexible Adjustment of Fan Position
By adjusting the fan position, you can easily match the height of the memory and enjoy unlimited cooling performance.
Any CPU Can Be the Right CPU
TOUGHAIR Series are designed to fit Intel and AMD sockets including the following models:
Intel: LGA 2066/2011/2011-3/1700/1200/1156/1155/1151/115
AMD: AM5/AM4
It just goes to show as Thermaltake launches the TOUGHAIR 710 Black CPU cooler that despite the increasing TDP of modern processors and the wide availability of AIOs, the reign of air-cooled solutions for processors is far from over.
