ASRock has announced the release of new Phantom Gaming, Steel Legend, and Challenger series graphics cards based on AMD’s new Radeon RX 7800 XT and Radeon RX 7700 XT GPUs. There are six models in total, all of which appear to feature some level of RGB or LED lighting. The ASRock Phantom Gaming Radeon RX 7800 XT, which boosts up to 2,565 MHz, is available for $529.99 at retailers that include Newegg.
ASRock AMD Radeon RX 7800/7700 XT Phantom Gaming
The ASRock AMD Radeon RX 7800 XT Phantom Gaming 16GB OC and ASRock AMD Radeon RX 7700 XT Phantom Gaming 12GB OC graphics cards both offer an extreme Boost Clock of up to 2565 MHz and 2599 MHz , and are equipped with the Phantom Gaming triple-fan cooling system to provide excellent cooling performance, as well as the Striped Ring Fans, Air Deflecting Fin and Ultra-fit Heatpipe to greatly improve cooling efficiency. The metal frame and metal backplate strengthens the structure and prevents the card from bending. The ARGB fan and ARGB LED panel combined with Polychrome SYNC software allows users to fully customize and control the lighting effects. With these unique features, the fancy black and red color scheme design and factory pre-overclocking make the ASRock AMD Radeon RX 7800 XT Phantom Gaming 16GB OC and ASRock AMD Radeon RX 7700 XT Phantom Gaming 12GB OC graphics cards perfectly tailored for 1440p gamers.
ASRock AMD Radeon RX 7800/7700 XT Steel Legend
The ASRock AMD Radeon RX 7800 XT Steel Legend 16GB OC and ASRock AMD Radeon RX 7700 XT Steel Legend 12GB OC graphics cards for white-themed PC builders achieve a Boost Clock of up to 2520 MHz and 2599 MHz. The triple-fan thermal design with the unique Striped Axial Fans, Air Deflecting Fin and Ultra-fit Heatpipe provide excellent heat dissipation. The metal frame and metal backplate strengthens the structure and prevents the plate from bending. The ARGB fans combined with Polychrome SYNC software allows users to customize and control the lighting effects. These useful features, unique white camouflage design along with factory pre-overclocking, make the ASRock AMD Radeon RX 7800 XT Steel Legend 16GB OC and ASRock AMD Radeon RX 7700 XT Steel Legend 12GB OC graphics cards the premium choices for white PC builders.
ASRock AMD Radeon RX 7800/7700 XT Challenger
The mainstream ASRock AMD Radeon RX 7800 XT Challenger 16GB OC and ASRock AMD Radeon RX 7700 XT Challenger 12GB OC graphics cards offer a Boost Clock of up to 2475 MHz and 2584 MHz. They are both equipped with a newly-designed stylish dual-fan cooler, the exclusive Striped Ring Fan, and Ultra-fit Heatpipe to provide efficient heat dissipation. The LED indicator makes the graphics cards more eye-catching. The metal backplate strengthens the structure. The high-quality Super Alloy Graphics Card components provide more stable operation. The factory default overclocking settings deliver higher performance. These practical designs enable the ASRock AMD Radeon RX 7800 XT Challenger 16GB OC and ASRock AMD Radeon RX 7700 XT Challenger 12GB OC graphics cards to be essentials of system integrators and mainstream users.
