Thermaltake has announced that the Ceres 300 TG ARGB and ARGENT E700 are now available for purchase in Matcha Green. Developed in response to the positive reception garnered by the Tower 200 Matcha Green Mini Chassis, the Ceres 300 TG ARGB ($99.99) is a mid-tower chassis with perforated panels that comes with three pre-installed CT140 cooling fans and support for up to 360 mm radiators, while the ARGENT E700 ($1,199.99) is a gaming chair that features real leather and a design by Studio F. A. Porsche. Thermaltake says that more products in Matcha Green (e.g., TH280 V2 ARGB Sync All-In-One Liquid Cooler) are on the way.
Ceres 300 TG ARGB Matcha Green Mid Tower Chassis Features
- Built for Massive Airflow: More than 55% of its panels are perforated
- With plenty of perforated cutouts, the Ceres 300 TG ARGB Matcha Green is designed with excellent cooling performance.
- Supports up to a 360mm Radiator at the Front and a 280mm at the Top
- Our Ceres 300 Matcha Green provides a lot of possibilities for cooling components. Users can choose to place a 360mm radiator at the front and a 280mm at the top.
- Two CT140 ARGB Sync PC Cooling Fans and One CT140 PC Cooling Fan Pre-installed
- Ceres 300 TG ARGB Matcha Green features two 140mm ARGB PWM fans at the front, and one 140mm PWM fan at the rear. The LED lighting effects can be manipulated with motherboard supported software. Users can create an amazing RGB lighting show while enjoying extreme cooling performance at the same time.
- Unify Your Fans with Your Build!
- Thermaltake launches brand-new CT series fans, allowing users to choose from black or white, RGB or non-RGB, to match whatever color scheme you have.
- Visually Pleasing, Totally Interactive
- Maximize your Ceres 300’s visual effects by upgrading it with our optimal LCD Panel Kit. The 3.9” LCD Display allows you to monitor real-time information and upload any images or GIFs to add extra flair using the TT RGB Plus 2.0 software. It also allows you to interact with the cooling components that feature the same LCD displays. The latest version includes weather mode and time mode for users to expand the usage of our LCD displays.
- Tempered Glass Side Panel
- The 4mm tempered glass panel on the left side offers stunning views and also allows users to fully display and admire all components in their full RGB glory.
- Display It Your Way
- Rotational PCI-E slots give you the option of mounting your graphics card either horizontally or vertically, providing plenty of flexible space for your system. If you choose to install your graphics card vertically, there is a space for the riser cable standoffs, allowing for a 90-degree riser cable installation.
- Air Intake and Exhaust
- The cooling performance of the Ceres 300 TG ARGB Matcha Green is remarkable thanks to two CT140 ARGB Sync PC Cooling Fans pre-installed at the front and one CT140 PC Cooling Fan pre-installed at the rear. Besides that, more than 55% of its panels are perforated, providing massive airflow through its perforated cutouts.
- Perfect Dust Protection
- There are fine removable filters at the top, front, bottom, left and right side of the chassis to provide excellent protection against dirt, and they are easily removable for cleaning.
- Opportunities For High-End Expansion
- The Ceres 300 TG ARGB Matcha Green Mid Tower chassis has good expandability. It can support a CPU cooler with a maximum height of 185mm, GPU placement of up to 370mm in length (without radiator), a power supply up to 220mm in length.
- Handy I/O Ports
- Two USB 3.0, one USB 3.2 Gen 2 Type C and HD Audio ports are placed on the top of the front panel to grant direct access when needed.
- Sync with Motherboard RGB Software
- Designed to synchronize with ASUS Aura Sync, GIGABYTE RGB Fusion, MSI Mystic Light Sync, and ASRock Polychrome. It supports motherboards with a 5V addressable RGB header, allowing you to control the lights directly from the software mentioned above without installing any extra lighting software or controllers. For more details, please visit ASUS, GIGABYTE, MSI, and ASRock official websites.
The Ceres 300 is an ATX case built for massive airflow, with more than 55% of its panels perforated. Now comes in three colors to choose from: Black, Snow, and Matcha Green. Matcha Green evokes feelings of soothing, echoing the Ceres series’s design on outstanding thermal performance. The Ceres 300 Matcha Green can accommodate up to a 360mm AIO radiator, five 140mm fans, or seven 120mm fans in total, providing an optimal cooling solution. Furthermore, it is pre-installed with two CT140 ARGB Sync PC Cooling Fans at the front and one CT140 PC Cooling Fan at the rear, enabling the air to be pushed further. To achieve a visually pleasing layout, the Ceres 300 Matcha Green not only possesses a new-colored appearance but also includes a tempered glass window panel on the left side, allowing you to show off the splendid inner components. In addition, a 3.9″ TFT LCD panel kit, available separately, can display real-time component information, time mode, weather mode, and even upload any images or GIFs using the TT RGB Plus 2.0 software. It is an ideal chassis striking a balance between cooling performance and aesthetics.
ARGENT E700 Real Leather Gaming Chair Matcha Green Features
- Premium Real Leather
- Fully covered real leather with 1 – 1.1mm in thickness over the entire seat and headrest. The use of real leather is known for its durability, moisture resistance, and easy maintenance. Embroidered with red elegant stitching and unsurpassed breathability design for optimal aeration and style.
- Race Car inspired Side Handles
- Designed to reflect a race car, the integrated side handles allow for tilting and elevating, find the perfect posture! Left side handle positions the seat back up to 126°. Right side handle adjusts the seat height in between 16.1 – 20.8” (41 – 53cm).
- Polished Aluminum Logo
- The Thermaltake logo plate located in the front middle is aluminum polished, be unique!
- First-Class Seating Experience
- The one-piece curved-back design intends to appear aesthetic and futuristic, additionally, its formation provides for a full body immersion, imitating a first-class seating experience.
- Perforated Leather Seat Design
- Perforated leather offers breathability to achieve heat dissipation and ventilation.
- Versatile Adjustments
- Four-directional armrest movements in height and width, for optimal support of the forearm to relieve wrist pressure and muscle strain.
- Adjustable Headrest
- Integrated headrest with lift adjustment up to about 1.9” (5cm).
- High Density Molded Foam
- Underneath the real leather is packed with high density molded foam of 143.3lbs/ft³ (65kg/m³). The use of high density and premium foam provide even weight distribution and firm body support while maintaining a sedentary posture.
- Sit Straight or Relax
- Sit back in four lockable angles: 107°, 113°, 119°, 126°.
- Class-4 Gas Spring
- Class-4 gas spring for maximized safety and reliability during height adjustments.
- 5-star Aluminum Base & Caster Wheels
- Premium grade 5-star aluminum alloy base with large 3” (7.5cm) caster wheels for enhanced stability. Suitable for soft and hard floors, without scratching the floor.
- Recommended Measurements
- Height: 5’6” – 6’2” (170cm – 190cm)
- Weight: 331 lbs (150kg)
The ARGENT E700 series is a collaboration with Studio F. A. Porsche features a unique racing bucket seat design and pursues a first-class seating experience with superior aesthetics and comfort. To satisfy preferences for various styles, the ARGENT E700 series incorporates 10 colors: Glacier White, Space Gray, Storm Black, Ocean Blue, Flaming Orange, Racing Green, Turquoise, Sanga Yellow, Saddle Brown, and the latest Matcha Green. Matcha green expresses a sense of freshness and tranquility. The graceful appearance color comes with a matte finish, fully showing the low-profile luxury of the ARGENT E700 Matcha Green. The matcha green also represents that while sitting on this premium real leather gaming chair, users can calmly conquer all challenges while gaming and at work.
