Cooler Master MASTERLIQUID 360 ATMOS AIO CPU Cooler Review
Sound Level Testing
While we were testing cooling capabilities, as outlined in our introduction article, we were also tracking the sound level of each of the coolers using a Risepro SPL meter attached to a boom arm pointed directly at the fans of the radiator at a distance of 12 inches. We recorded the dB(A) level for each fan and pump speed tested. The ambient room sound level measured 33 decibels.
Max Fans – 100% Pump Speed
Cooler Master MASTERLIQUID 360 ATMOS sound level testing results at max rpm fans
At the highest fan levels, the Cooler Master MASTERLIQUID 360 ATMOS made a significant contribution to the overall room noise, but in a more wind-rushing and non-droning type of way. Subjectively, the CORELIQUID E360 made its presence known more (and, well, apparently quantitatively as well).
Cooler Master MASTERLIQUID 360 ATMOS sound level testing results at 1500 rpm fans
Dropping down to 1500 RPM, the Cooler Master MASTERLIQUID 360 ATMOS basically fades to being near inaudible, much like the PL360 FLUX. The CORELIQUID E360 got a lot quieter, but since it only lost 300 RPM from its overall speed, it was still a decent contributor to room noise.
Cooler Master MASTERLIQUID 360 ATMOS sound level testing results at 1000 rpm fans
Dropping down to 1000 RPM, all three units are essentially inaudible as the 1.3 dB(A) difference at this point is academic rather than practical.
Cooler Master MASTERLIQUID 360 ATMOS sound level testing results at 600 rpm fans
At the lowest fan setting, we again find an exercise in academic differences in dB(A) levels for fans that we can’t really hear.
Cooling Performance
Installation Effort
Sound Level
We tested the Cooler Master MASTERLIQUID 360 ATMOS against a couple of other 360mm AIOs on our second generation AIO testbed and found that it delivered solid performance with a reasonable amount of noise and is positioned at a fair price.
