ASRock has announced the Radeon RX 7900 XT Phantom Gaming White 20GB OC, a new version of one of its more premium RDNA 3 graphics cards that comes in a white instead of black color scheme. The card features a boost frequency of up to 2,450 MHz (50 MHz higher than reference) and counts a striped ring fan, premium thermal pad, and ARGB among its feature set. Connectivity comprises 3x DisplayPort 2.1 and 1x HDMI 2.1 ports.
ASRock Radeon RX 7900 XT Phantom Gaming 20GB OC Overview
Clock: GPU / Memory
- Boost Clock: Up to 2450MHz / 20Gbps
- Game Clock: 2075MHz / 20Gbps
Key Specification
- AMD Radeon RX 7900 XT GPU
- 20GB GDDR6 on 320-Bit Memory Bus
- 84 AMD RDNA 3 Compute Units (With Rt+Ai Accelerators)
- 80MB AMD Infinity Cache Technology
- PCI Express 4.0 Support
- 2 x 8-pin Power Connectors
- 3 x DisplayPort 2.1 / 1 x HDMI 2.1
Key Features
- Polychrome SYNC
- Phantom Gaming 3X Cooling System
- Striped Ring Fan
- Reinforced Metal Frame
- Stylish Metal Backplate
- 0dB Silent Cooling
- Super Alloy Graphics Card
ASRock Radeon RX 7900 XT Phantom Gaming White 20GB OC Graphics card has 84 compute units and boasts 5376 stream processors with a Boost Clock of up to 2450 MHz and a Game Clock of up to 2075 MHz. With 20GB of GDDR6 high-speed memory clocked at 20Gbps Effective and 80 MB of Infinity Cache, delivering 4K gaming at the highest settings.
ASRock Radeon RX 7900 XT Phantom Gaming White 20GB OC graphics cards use the triple-fan Phantom Gaming 3X cooling system with the customized 100/100/100mm Striped Ring Fans, Air Deflecting Fin, and Ultra-fit Heatpipe to provide superior cooling performance. ARGB LEDs that support Polychrome SYNC allow users to customize lighting effects, while the metal frame and backplate prevent the PCB from bending. The Super Alloy Graphics Card components provide stability for long-term operation. With its great performance and rich features, it can fully satisfy the needs of gamers.
