MONTECH Unveils KING 95 and KING 95 PRO Mid-Tower Curved PC Cases with Adjustable Fan Bracket and Interchangeable Front Panels
Image: MONTECH
MONTECH has unveiled its KING 95 and KING 95 PRO PC cases featuring options for both style, customization, and optimal cooling. The KING series supports from Mini-ITX to ATX form factors, with clearance for up to 420mm GPUs. An industrial-grade curved 4mm tempered glass panel adds a touch of elegance but when things get hot it can be swapped out for a mesh panel for optimal air flow. MONTECH has also patented an adjustable side fan bracket for further cooling optimization along with support for up to 360mm AIO on the top, and/or 240mm AIO on the side, of the case and up to a 175mm tall CPU cooling tower.
Image: MONTECH
Both cases come with an ARGB strip in the front while the KING 95 PRO includes a set of six pre-installed ARGB fans. Case color options include Gentleman Black, Pure White, Vibrant Red, or Prussian Blue with prices ranging from $109-125 for the KING 95 and then $149-$169 for the KING 95 PRO. Storage support options include up to either 5 x 3.5” HDDs and 3 x 2.5” SSDs or up to a total of 8 x 2.5” SSDs. Users can install up to a 190mm PSU.
Image: MONTECH
Specifications (via product page):
ModelKING 95KING 95 PRO
Form FactorMiddle Tower CaseMiddle Tower Case
MotherBoard SupportATX, Micro-ATX, Mini-ITXATX, Micro-ATX, Mini-ITX
Front I/OType-C*1/USB3.0*2/Mic/Audio*1/LED ButtonType-C*1/USB3.0*2/Mic/Audio*1/LED Button
ColorsBlack/White/Red/BlueBlack/White/Red/Blue
Dimension (L*W*H)475*300*442mm475*300*442mm
PCI Slots77
MaterialsSPCC/Tempered glassSPCC/Tempered glass
Compatibility/ MaximumCPU Cooler175mm175mm
GPU420mm420mm
Power Supply190mm ATX PSU190mm ATX PSU
Drive Bay2.5″ SSD88
3.5″ HDD55
Fan SupportSide120mm*2/140mm*2120mm*2/140mm*2
Top120mm*3/140mm*2120mm*3/140mm*2
Rear120mm*1120mm*1
Bottom120mm*3/140mm*2120mm*3/140mm*2
Radiator SupportSide120/140/240/280mm120/140/240/280mm
Top120/140/240/280/360mm120/140/240/280/360mm
Rear120mm120mm
Pre-installed Fan(s)SideN/A140mm*2 (Reversed ARGB PWM Fans)(The compatibility with GPU becomes 275mm with 63cm-high water cooling installed.)
BottomN/A120mm*3(Reversed ARGB PWM Fans)
RearN/A120mm*1 (ARGB PWM Fans)
EAN47105627439444710562747942
Table: MONTECH
Pre-order options for the KING 95 and KING 95 Pro are now available on Newegg.
Press Release (via official news page):
MONTECH Unveils the Versatile Mid-Tower with Curved Elegance – KING 95 and KING 95 PRO
Taipei, Taiwan – MONTECH, an innovative PC components and peripherals brand, proudly unveils its latest flagship model: KING 95 and KING 95 PRO. The KING 95 showcases a seamless blend of durability and craftsmanship with the robust steel framework and 4mm curved tempered glass, allowing for an immersive panoramic view. After a year of rigorous testing, KING 95’s industrial-grade curved tempered glass boasts optimal curvature and unmatched durability, ensuring crystal-clear component visibility from every angle. The KING 95 further enriches user experience through a vast array of build options, bolstered by enhanced cooling capabilities. Available in Gentleman Black, Pure White, Vibrant Red, or Prussian Blue.
Enhanced Cooling
As thermals are paramount for peak performance, the KING 95 series stands out with a wide range of cooling capabilities. At the forefront of its design, features a patented adjustable fan bracket, which allows rotation to the front while also providing fan support. The KING 95 also features an interchangeable premium mesh front panel that can be attached to enhance airflow.
Furthermore, the KING 95 features easily removable top and side panels, equipped with built-in dust filters ensuring optimal airflow. Moreover, the KING 95 can support up to eleven fans, providing a comprehensive cooling solution. The KING 95 PRO comes equipped with six pre-installed ARGB PWM fans (4 x 120mm and 2 x 140mm). Amongst the pre-installed fans, the bottom and side fans are reversed fans, and the rear is standard.
Aesthetics & Design
Bolstering a seamless blend of aesthetics and versatility, the KING 95 series stands out with a stunning 4mm curved tempered glass, providing an uninterrupted panoramic view. Thoughtful design and engineering is evident with its streamlined cable management system, ensuring a clutter-free and polished interior. Adding a touch of luminance, the ARGB light strip infuses a dynamic ambiance, allowing users to customize lighting.
Hardware Compatibility
The KING 95 offers exceptional versatility and is compatible with a range of options to accommodate various hardware and components. It supports motherboards from Mini-ITX to ATX, ensuring compatibility with a range of systems. The KING 95 also offers capacity for up to 360mm radiator at the tops and CPU cooling towers of up to 175mm in height, making it an ideal choice for powerful cooling systems. Furthermore, the KING 95 provides generous clearance for large GPUs, offering support of up to 420 mm in length. In terms of storage capacity, the KING 95 offers ample options featuring 5 x 3.5” HDDs + 3 x 2.5” SSDs or 8 x 2.5” SSDs drive bays, ensuring abundant storage options.
Discussion (9 replies)
Grimlakin 👍 1
You know what I want. I want a big effing case where the top and bottom can be swapped so I can change the orientation of the case. And the I/O panel on the front can be flipped. Every case out there today has a window on the left side (when facing the case) and I don't see many that have a right hand window. My PC is on the left. Hence one of the reasons I don't care about flashy lights or pretty parts.
LazyGamer
LazyGamer 👍 1
Lian Li O11-D Evo.
Denpepe
Denpepe 👍 1
be quiet should have what you want https://www.bequiet.com/en/case/4425
"LazyGamer, post: 79664, member: 1367" wrote:
Lian Li O11-D Evo.
Not bad at all. Thanks! That might be the next case I use... in another decade. I tend to use cases for a few builds.
Lian Li O11-D Evo.
Interesting. Didn't know about that one. I won't be on the hunt anytime soon, like @Grimlakin I tend to go about a decade both of the ones I recently got barely have more than a year on them.
Niner51
I have used those dual chamber cases, but I keep coming back to my 7000D/X case. Just can't beat a full tower IMO.
D
Ditchinit 👍 2
Lian Li O11-D Evo.
I can vouch for this one. I built my latest system in it. The first came with busted glass, but Amazon took it back and replaced it with one that is whole. Not all the options are clearly explained in the manual. I have two 360 AIOs (CPU and GPU, top and side, respectively) and an EATX motherboard. I also bought the expanded USB hubs for the bottom to give more access flexibility due to where I have it located.
My only quibble is that, while they claim the case is EATX compatible, the motherboard slightly overhangs the side AIO. The EATX is just wide enough that the plugs with wires overlap in front of the side fans by about 40% fan diameter or so. Lian Li's marketing department probably stretched the truth a bit (for a certain set of build assumptions).
There's plenty of room for extra fans on the bottom and back, and a nice removable hard drive cage behind the motherboard and above the power supply. Some pass-through wire routing can get cramped but can be achieved with determination.
YMMV
LazyGamer
LazyGamer 👍 2
@Ditchinit, that's pretty much my summary for the older O11-D XL. Large, but somehow slightly cramped, and 'stretching' the definition of EATX compatible. I will say that EATX isn't really a standard beyond 'deeper than ATX, but no taller', and the boards do fit - but the overhang is a real pain there.
D
The value is the flexibility in how you initially build it. I don't know how often people rebuild their cases after the first. Maybe some do for a change of pace, I don't know. Rebuilding is very possible with this case provided all the extra parts are kept. It is well engineered, and perhaps maybe a bit over engineered in some ways. Everything fit well, and while I only built mine in one configuration, I would expect everything to fit well in the other configuration, too.
