Alan Wake 2 GPU Performance Review – GeForce RTX 40 Series vs Radeon RX 7000 Series
Radeon RX 7000 Series – LOW Ray Tracing Preset
Now that we know the AMD Radeon RX 7000 series GPUs take such a big hit with enabling Path Tracing in Alan Wake 2, we wanted to re-evaluate their performance but this time using the “Low” Ray Tracing quality preset mode. This means that Path Tracing will not be enabled now, but also this is the lowest quality Ray Tracing option also, so Ray Tracing quality will be lower than “High” and so therefore we will only show the Radeon RX 7000 series performance on this graph and see if any GPU is playable with “Low” Ray Tracing. We will also include upscaling using FSR 2 on the graph too, to see how that plays a role in making something playable.
4K
Alan Wake 2 4K Quality Preset High FSR 2 Quality Radeon RX 7900 XTX Ray Tracing presets compared performance graph
Well, even by enabling “Low” Ray Tracing the Radeon RX 7900 XTX is still not playable at 4K even with upscaling, only hitting maybe 50 FPS. You can, however, see the huge difference between “High” Ray Tracing and “Low” Ray Tracing on the Radeon RX 7900 XTX. Enabling “High” Ray Tracing which enables Path Tracing takes a 50% hit in performance compared to “Low” Ray Tracing without Path Tracing.
1440p
Alan Wake 2 1440p Ray Tracing Low Radeon RX 7000 series GPUs performance compared performance graph
Ok, things look a lot better for the AMD Radeon RX 7000 series GPUs at 1440p when using the “Low” Ray Tracing preset in Alan Wake 2, instead of “High.” Of course, it is the lowest Ray Tracing quality, and it does not have Path Tracing enabled, but at least the Radeon RX 7900 XTX is now playable at 1440p with FSR 2 enabled.
Yeah, it still takes upscaling really even at 1440p to bring the Radeon RX 7900 XTX up to levels above 60 FPS. Without upscaling, you can hit about 53 FPS with it, and that honestly is sort of acceptable in this game. The Radeon RX 7900 XT is also playable with upscaling, but it does require that FSR 2 at 1440p to be playable, and again, this is all at a display resolution of 1440p here, not 4K. The Radeon RX 7800 XT with upscaling is also playable, barely, but cards below that are not.
1080p
Alan Wake 2 1080p Quality Preset High Ray Tracing Low FSR 2 Quality Radeon RX 7700 XT and Radeon RX 7600 performance compared performance graph
We did find that the AMD Radeon RX 7700 XT could be playable in Alan Wake 2 at 1080p using FSR 2 upscaling on the “Low” Ray Tracing Preset. Otherwise, that’s about it, the Radeon RX 7600 has no chance of using Ray Tracing.
