ASRock Announces AMD Radeon RX 7900 GRE Steel Legend and Challenger 16 GB OC Series Graphics Cards
Image: ASRock
There are two more additions to AMD’s global GRE lineup as ASRock announces its Radeon RX 7900 GRE graphics cards. ASRock has announced its Radeon RX 7900 GRE triple fan, white-themed Steel Legend 16 GB OC, and the dual-fan Challenger 16 GB OC which comes in a more traditional black design. Both cards feature high-speed 16 GB GDDR6 memory running at 18 Gbps. Each also comes with a factory overclock for optimal performance. Pricing and availability have not yet been announced.
Product Links:
Additional Features (via Press Release):
  • AMD RDNA 3 architecture featuring redesigned compute units, second-generation AMD Infinity Cache and raytracing technologies, and increased AI throughput
  • AMD Radiance Display Engine provides 12 bit-per-channel color for up to 68 billion colors for incredible color accuracy with support for DisplayPort 2.1, full AV1 encoding and is optimized for high-performance, high-resolution 4K/1440p gaming, streaming, and content creation applications.
  • PCIe 4.0 x16 support
  • ASRock exclusive features: Striped Ring/Axial Fan, Air Deflecting Fin, Ultra-fit Heatpipe, Metal Backplate, and Polychrome SYNC technology to provide great cooling efficiency, solid construction, ARGB lighting effects.
ASRock AMD Radeon RX 7900 GRE Steel Legend 16GB OC
Image: ASRock
The ASRock AMD Radeon RX 7900 GRE Steel Legend 16GB OC Graphics Card features a triple-fan design for optimal cooling of the Navi 31 GPU which has a factory overclock of up to 2333 MHz. The fans can also operate in silent 0dB mode when not under load. The card has a metal frame and backplate for added support. ARGB fan Lighting effects can be controlled via software or turned on/off manually via a switch on the PCB. Power is provided via 2x 8-pin connectors and an 800 PSU is recommended. Up to four displays can be connected via 3x DP 2.1 (limited to 2.1 on one or two ports but 1.4a on all three simultaneously) and 1x HDMI 2.1 ports. Dimensions for the 2.8 slot card are 304 x 131 x 56 mm.
ASRock AMD Radeon RX 7900 GRE Challenger 16GB OC
Image: ASRock
The ASRock AMD Radeon RX 7900 GRE Challenger 16GB OC is perhaps the best of both worlds. With its dual-fan design, and slightly lower 2293 MHz factory overclock, this card uses less space and power out of the box. It also features 2x 8-pin power connectors but the PSU recomendation is lowered to 750 Watts. The slightly smaller dimensions for the 2.55-slot card are 269 x 130 x 51 mm. Display connectivity is similar as well but ASRock has further specified that its HDMI 2.1 port supports up to FRL 12 Gbps, and the DP 2.1 ports support up to UHBR3 13.5 Gbps. The cooling fans support 0dB for silent operation while under light loads and do not feature ARGB but there are LED light strips on the frame.
