The Sharkoon Rebel C20 ITX Is a PC Case That Can Be Oriented Either Vertically or Horizontally, Fit Large GPUs, and up to 360mm Radiators
Image: Sharkoon
The Sharkoon Rebel C20 ITX is a mini-ITX form factor case designed with high-performance PC computing in mind while being small and elegant in its simple design. Available in RGB or non-RGB models, the Sharkoon Rebel C20 ITX can accommodate GPUs up to 365 mm in length. The Rebel C20 ITX has also been designed so that users can orientate it either horizontally or vertically, further providing options for those with limited desk or office space or personal preferences.
Perforated metal panels, all of which include dust filters, allow an assortment of cooling configurations with up to nine fans to ensure optimal airflow. Those using fewer fans can install up to a 360 mm radiator. CPU coolers up to 175 mm tall can be installed. The front of the case provides a TRRS audio port, 2x USB3 ports, and one USB Type-C port. Sharkoon has not yet provided pricing and availability details for the Rebel C20 ITX.
Press Release:
“A Mini-ITX Case Also Made for High-End Hardware
Sharkoon Technologies is an international supplier of high-quality, high-performance PC components and peripherals and is now launching the Rebel C20 ITX. Even though this PC case is primarily designed for mini-ITX mainboards as well as SFX and SFX-L PSUs, the Rebel C20 ITX should also be able to accommodate the largest graphics cards and radiators. In addition, the case can be positioned either vertically or horizontally and is available either as a version without fans or as a version with pre-installed addressable RGB fans for cooling.
Despite its dimensions of just 45.7 x 20.8 x 30.1 centimeters, the Rebel C20 ITX should also be able to accommodate the largest modern graphics cards of the RTX 4090 series as well as radiators of up to 360 millimeters.
Horizontal or Vertical Installation
As the Rebel C20 ITX can be positioned either vertically or horizontally, it can not only serve as a gaming PC but can also become a compact PC that fits into any living room or office room at home.
Lots of Space for Cooling
Apart from the aforementioned radiators, a total of nine 120-millimeter fans can be installed inside the Rebel C20 ITX. The RGB version of the case, the Rebel C20 ITX RGB, is equipped with an RGB controller and three pre-installed 120-millimeter fans with addressable RGB illumination.
Protected Air Intake All-Around
Both versions of the Rebel C20 ITX have paneling with perforated surfaces to provide an optimal ventilation of the installed hardware. All the main areas of air intake are additionally protected with dust filters.
Modern Connectivity on Case Front
As well as conventional USB ports, both versions of the case are equipped with USB-C and TRRS ports for an uncomplicated connection to mobile and storage devices.”
Specifications (per product page):
  • Form Factor: Mini-ITX
  • Expansion Slots: 4
  • Weight & Dimensions: 6.2 kg, 47.1 (L) x 20.8 (W) x 30.1 (H) cm
  • Max. Drive Bays: 1x 3.5″, up to 5 x 2.5″
  • I/O: 1x Type-C (USB 3.2 Gen 2), 2x USB 3.0 (Front), 1x Audio (Top):
  • Fan Configuration: Side Panel (3x 120 mm or 2x 140 mm Fan or Radiator (Optional)), Rear Panel (1x 120 mm Fan (Optional)), Top Panel (3x 120 mm or 2x 140 mm Fan (Optional)), Bottom Panel )2x 120 mm Fan (Optional))
  • Max. Length Graphics Cards: up to 36.5 cm
  • Max. Height CPU Cooler: up to 17.5 cm
  • Max. Length PSU: 17.5 cm
  • Max. Height Radiator incl. Fan: 7.0 cm
