GIGABYTE X870 AORUS ELITE WIFI7 Motherboard Revealed for AMD Socket AM5 Ryzen 9000 / 8000 / 7000 Series Processors
Image: GIGABYTE
Features and specifications have been revealed for the GIGABYTE X870 AORUS ELITE WIFI7 AM5 socket ATX motherboard. The GIGABYTE X870 AORUS ELITE WIFI7 is essentially an update to the previous more budget-friendly B650/X670 motherboards that now offers USB4 and Wifi 7 sans some of the extra features found in X870E AORUS Master. As noted by TechPowerUp, the PCB is 6 layers and the use of the 3rd M.2 Gen 5 slot removes 8 lanes from the PCIe 5.0 x 16 slot.
Some modern features include the EZ-latch quick-release solutions for both the PCIe and M.2 slots making it a breeze to attach or remove graphics cards and NVME drives. An abundance of heatsinks aid in keeping drives cool while a high-gain antenna provides optimal WiFi connectivity. The Realtek ALC1220 HD audio CODEC with 120 dB SNR paired with audio-grade capacitors offers a premium audio solution. Full specifications can be found here. GIGABYTE has not yet revealed pricing for the X870 AORUS ELITE WIFI7 but it is expected to be a more budget-friendly offering than the X870E AORUS Master.
Key Features (via product page):
  • AMD Socket AM5:Supports AMD Ryzenâ„¢ 9000 / 8000 / 7000 Series Processors
  • Power Delivery: Digital twin 16+2+2 phases VRM solution
  • Dual Channel DDR5:4 x DIMMs with AMD EXPOâ„¢ Memory Module Support
  • WIFI EZ-Plug: Quick and easy design for Wi-Fi antenna installation
  • EZ-Latch Plus: PCIe and M.2 slots with Quick Release & Screwless Design
  • EZ-Latch Click: M.2 heatsinks with screwless design
  • Sensor Panel Link: Onboard video port for hassle-free in-chassis panel setup
  • Friendly UI: Multi-Theme, AIO Fan Control, and Q-Flash Plus Auto Scan in BIOS and SW
  • Ultra-Fast Storage:4 x M.2 slots, including 3* PCIe 5.0 x4
  • Efficient Thermal: VRM Thermal Armor Advanced & M.2 Thermal Guard L
  • Fast Networking:2.5GbE LAN & Wi-Fi 7 with directional Ultra-high gain antenna
  • Extended Connectivity: Dual USB4 Type-C with DP-Alt, HDMI
  • Audio: Realtek ALC1220 HD Audio & Audiophile Grade Capacitors
  • Ultra Durable PCIe Armor: The metal back plate of PCIe x16 slot for enhanced durability
  • PCIe UD Slot X: PCIe 5.0 x16 slot with 10X strength for graphics card
Connectivity Features (via product page):
Image: GIGABYTE
  1. Q-FLASH PLUS Button
  2. Wi-Fi 7 with Ultra-high gain Antenna
  3. WIFI EZ-Plug
  4. 4 x USB 2.0
  5. 1 x HDMI
  6. Dual USB4 Type-C® up to 40Gb/s with DP-Alt
  7. 4 x USB 3.2 Gen 1
  8. 2 x USB 3.2 Gen 2
  9. 2.5 GbE LAN
  10. Front USB-C 20Gb/s
  11. 4 x SATA 6Gb/s
  12. Sensor Panel Link(HDMI)
  13. Unleash precision in gaming audio including ALC1220 HD Audio with Audiophile Grade Capacitors
  14. RGB FUSION including 1 x RGB LED Header and 3 x ARGB LED Headers
Other Specifications:
  • Memory Support for DDR5 8000(OC) / 7800(OC) / 7600(OC) / 7200(OC) / 7000(OC) / 6800(OC) / 6666(OC) / 6600(OC) / 6400(OC) / 6200(OC) / 6000(OC) / 5600(OC) / 5200 / 4800 / 4400 MT/s memory modules
  • 4 x DDR5 DIMM sockets supporting up to 256 GB (64 GB single DIMM capacity) of system memory
  • Dual channel memory architecture, Support for non-ECC Un-buffered DIMM 1Rx8/2Rx8/1Rx16 memory modules, Support for AMD EXtended Profiles for Overclocking (AMD EXPOâ„¢) and Extreme Memory Profile (XMP) memory modules
  • Onboard Graphics: Integrated Graphics Processor with AMD Radeonâ„¢ Graphics support+ASMedia USB4® Controller:
  • 2 x USB4® USB Type-C® ports, supporting USB4 and DisplayPort video outputs and a maximum resolution of 3840×2160@240 Hz
  • Support for DisplayPort 1.4 version and HDR., Integrated Graphics Processor with AMD Radeonâ„¢ Graphics support: 1 x HDMI port, supporting a maximum resolution of 4096×2160@60 Hz
  • Support for HDMI 2.1 version, HDCP 2.3, and HDR.
    ** Support native HDMI 2.1 TMDS compatible ports.
  • 1 x front HDMI port, supporting a maximum resolution of 1920×1080@30 Hz
  • Support for up to quad-display at the same time
  • Audio: Realtek® ALC1220 CODEC, The back panel line out jack supports DSD audio.
  • High Definition Audio: 2/4/5.1/7.1-channel, You can change the functionality of an audio jack using the audio software. To configure 7.1-channel audio, access the audio software for audio settings.
  • Support for S/PDIF Out
  • LAN: Realtek® 2.5GbE LAN chip (2.5 Gbps/1 Gbps/100 Mbps)
  • Wireless Communication module: MediaTek Wi-Fi 7 MT7925 (PCB rev. 1.0)
  • WIFI a, b, g, n, ac, ax, supporting 2.4/5/6 GHz carrier frequency bands
  • BLUETOOTH 5.4
  • Support for 11be 160MHz wireless standard
  • Realtek® Wi-Fi 7 RTL8922AE (PCB rev. 1.1), WIFI a, b, g, n, ac, ax, supporting 2.4/5/6 GHz carrier frequency bands
