(PR) Cooler Master, a leading provider of PC components, gaming peripherals, and tech lifestyle solutions, today announced the launch of the Hyper 612 APEX, an all-new CPU air cooler engineered for users who demand top-tier cooling in a streamlined form factor. The Hyper 612 APEX features in-house designed superconductive composite heat pipes and a powerful Mobius 120P fan, delivering superior cooling while remaining 30% smaller than its predecessor. This reduction in size ensures compatibility with large memory modules, making it easier to install without sacrificing performance. Ideal for gamers, content creators, and overclockers, the Hyper 612 APEX balances high performance and aesthetics.
โThe Hyper 612 APEX is designed to meet the needs of users who want efficient cooling without the bulk,โ said Jimmy Sha, Cooler Master CEO. โWith our advanced heat pipe technology and compact design, this cooler delivers high-performance results while staying user-friendly for a wide range of builds.โ
Key Features of the Hyper 612 APEX
- Superconductive composite heat pipes: Six advanced heat pipes handle heavy thermal loads, ideal for overclocking.
- Compact design: 30% smaller than previous models, providing easier installation and compatibility with large memory modules.
- Quick installation: Removable magnetic top cover and easy-to-remove fan streamline the setup process.
- Durable nickel-plated copper base: Resists corrosion and enhances long-term reliability.
- Powerful Mobius 120P fan: Designed for high-pressure airflow while keeping noise levels to a minimum.
The Hyper 612 APEX is available to pre-order on the Cooler Master Store through November 30, 2024, in the United States, Europe, and Taiwan. Full channel availability is expected in January 2025.
(PR) Cooler Master, a leading provider of PC components, gaming peripherals, and tech lifestyle solutions, today announced the MasterLiquid 360 Atmos Stealth, a brand-new, all-black, non-LED version of the high power MasterLiquid 360 Atmos AIO cooler. The Atmos series is known for its signature engineering seen in features such as the dual chamber design and customizable pump top cover. Now all those features come packaged in a sleek and stealthy aesthetic.
Key features and benefits of the MasterLiquid 360 Atmos Stealth
- Refined dual chamber design: Our signature dual chamber pump has been refined for enhanced cooling synergy.
- Customizable pump top cover: Removable pump top cover, customizable with your own 3D-printed designs.
- Eco-friendly pump cover: The entire pump cover is manufactured with eco-friendly recycled plastics, putting our environment first.
- Mobius 120 black fans: Pre-installed Mobius 120 mm, 2400 rpm fans further improve cooling performance and simplify user installation.
- Daisy-chaining fan connections: Reduces the number of cables needed, leading to a cleaner and more organized system.
- Updated CPU compatibility: The Atmos Stealth is compatible with all of the latest AMD and Intel CPUs.
With a minimalist aesthetic design, The Atmos Stealth has been crafted to bring all the AIO power of the Atmos series to builders who want a more lowkey look for their machines. Leap into the future of liquid cooling with the MasterLiquid 360 Atmos Stealth.
(PR) Cooler Master, a leading provider of PC components, gaming peripherals, and tech lifestyle solutions, today announced the MasterLiquid Core II, a next level liquid cooler that comes in both 240mm and 360mm sizes. This latest version of Cooler Masterโs MasterLiquid series builds on the excellence of that renowned series of liquid coolers while bringing an array of new features to the table. With a refined G9R dual chamber pump, updated CPU compatibility, and more, the MasterLiquid Core II is an upgrade fit for the next generation.
Key features and benefits of the MasterLiquid Core II
- Dual chamber pump: Upgraded design resulting in a compact cooler with superior performance.
- Updated CPU compatibility: The Core II is compatible with all the latest AMD and Intel CPUs.
- Innovative design: An infinity mirror pump cover gives the Core a stellar aesthetic.
- Revamped fans: Brand-new fan blades and revamped visuals deliver outstanding performance with a fresh look.
- Easy installation: Now includes a quick-mount kit compatible with all mainstream processor sockets, along with pre-installed fans.
- Optimum tubing length: 400mm of tubing enables effortless mounting in any orientation.
The MasterLiquid Core II brings silent cooling power and a user-friendly install experience to builds of every type. Take your setup into the modern era with the MasterLiquid Core II.
(PR) Cooler Master, a global leader in PC components, has released the SickleFlow Edge 120 ARGB 3-Pack Fan Kit and the SickleFlow Edge White 120 ARGB 3-Pack Fan Kit. The SickleFlow Edge 120 represents the pinnacle of Cooler Masterโs air-cooling technology and is now made available in a highly convenient 3-pack variant in both black and white colorways, allowing for easy cooling expansion.
This release of the SickleFlow Edge 120 features all the same great performance specs of the original release, now with a few updates. The fan blade design has been further enhanced to provide higher fan speeds, air pressure, and airflow while maintaining low noise levels. Further improvements have been made to the loop dynamic bearing system to provide additional noise reduction. The fanโs frame has been redesigned to reflect a more cohesive aesthetic, and an A1 mini-LED controller has been included with the fans to allow for the ultimate in fan control and customization.
The SickleFlow Edge 120 ARGB 3-Pack Fan Kit is a great choice for PC enthusiasts looking to expand their cooling set up and get an extra performance edge out of their build.
