SAPPHIRE NITRO+ B850A WIFI 7 Motherboard Review
M.2 Storage Performance
In the above CrystalDiskMark screenshots, we are testing each M.2 slot individually, starting with the primary M.2_1 slot, then M.2_2, and finally M.3_3. Now, remember, technically, M.2_1 (the primary slot) is specified as being PCIe 5.0 x4, while the other two are supposed to be PCIe 4.0 x4. Well, with our PCIe Gen5 NVMe Corsair MP700 PRO 2TB PCIe Gen5 NVMe SSD, we can see that indeed the primary M.2_1 slot is operating correctly and as fast as it should be, maxing out the drive at PCIe Gen5 performance.
However, what was surprising was to find out that the secondary M.2_2 slot can also operate at PCIe 5.0 x4 speeds, as it performed just the same as the primary slot, with full PCIe Gen5 NVMe performance. The third slot, M.2_3, performed at its speed of PCIe 4.0 x4. We did indeed confirm in CrystalDiskInfo that the secondary M.2_2 slot was running in the PCIe 5.0 x4 interface speed.
USB-C Performance
The SAPPHIRE NITRO+ B850A WIFI 7 supports USB 3.2 Gen 2 10Gbps performance on three of its Type-A ports, and on one Type-C port on the rear. We wanted to test the USB-C port and see how well it performs, and confirm it can run up to 10Gbps. We plugged in an ADATA SE920 1TB External SSD Storage drive, which supports up to USB 4 40Gbps over a Type-C connection. In the USB Flash Benchmark test, we can see that it peaked at near 945MB/s transfer rate, and both read and write performance followed a very consistent and linear trajectory, with consistency. Transferring a 10GB file maxed out at 903MB/s and took 11.3 seconds to transfer.
VRM Temperature
HWINFO64 doesn’t capture any specific VRM temperature sensors on the SAPPHIRE NITRO+ B850A WIFI 7; in the screenshot above, PCH is actually the CPU package temperature, it seems. The CPU temperature is not exactly the core temperature here. The chipset temperature is kept well-cooled, with no issues with temperatures. When running Cinebench for 30-minutes, the VRM heatsinks were only warm to the touch, not hot. Using a laser temperature device, the top heatsink hit a maximum temperature of 49.6c on the surface, and the primary heatsink hit a maximum temperature of 41.4c. We don’t see any problems with cooling or temperatures from what we can gather with what we have, though we have not directly tested the VRM temperatures, and there isn’t a built-in sensor that shows that.
The FPS Score
The SAPPHIRE NITRO+ B850A WIFI 7 is SAPPHIRE's entry into the motherboard realm for $189.99. The SAPPHIRE NITRO+ B850A WIFI 7 worked well in testing, allowing for top-end CPU performance, PBO, and memory overclocking. It provides all the features you need for a high-end gaming system, at a great value pricing under $200. There are a few cons, such as the location of the primary M.2 slot, but otherwise you get a lot of value for your money. Where it shines, is in the performance, and capability.
