Samsung Launches World’s Fastest Dual-Mode 27″ Monitor, the Odyssey G6 (G60H) Featuring a 1,100 Hz Refresh Rate
Image: Samsung
How fast is fast enough? Well, we’ll probably never know, but Samsung has made sure its Odyssey G6 (G60H) is a step ahead with a 1,100 Hz refresh rate. Originally announced last December with a slightly lower refresh rate of 1,040 Hz and using an IPS panel, the Odyssey G6 (G60H) is a dual-mode gaming monitor that supports NVIDIA G-Sync and AMD FreeSync to minimize screen tearing. It can operate at the ridiculously fast aforementioned 1,110 Hz rate in FHD (1080p), or a still impressive 600 Hz at QHD (1440p). Now, one does have to wonder how fast anyone needs to play Pong or what CPU/GPU combination will be required to do so at 1,100 FPS, but this version of the G60H is ready for you when you do get that hardware. Obviously designed for competitive gaming, but the question of what kind of system hardware configuration is needed and what titles can achieve that refresh rate remains valid.
Image: Samsung
Other features include Samsung’s HDR10+ GAMING for enhanced image quality in bright and dark scenes, along with its Black Equalizer technology to preserve details in dark scenes. Connectivity is provided 1x DP 2.1 (Samsung didn’t provide the version in its press release, but likely to be UHBR20) and 2x HDMI 2.1 ports.
Specifications (via Samsung CA):
  • Screen Size (Class): 27″
  • Flat / Curved: Flat
  • Active Display Size (HxV): 596.7 x 335.7 mm
  • Aspect Ratio:16:9
  • Panel Type: IPS
  • Brightness (Typical): 400 cd/㎡
  • Brightness (Peak): 450 cd/㎡
  • Brightness (Min): 280 cd/㎡
  • Contrast Ratio: 1,000:1
  • HDR(High Dynamic Range): HDR10
  • HDR10+: HDR10+ GAMING
  • Resolution: QHD (2560 x 1440)
  • Response Time (ms): 1 (GTG) (ms)
  • Viewing Angle: (H/V)178°(H)/178°(V)
  • Colour Support: Max 1B
  • Colour Gamut (sRGB Coverage): 99 %
  • USB-B Upstream Port: 1
  • USB Type-A Downstream Port: 2 EA
  • USB Type-A Downstream Version: 3.2 Gen1
The Samsung Odyssey G6 (G60H) is available to pre-order from Amazon now and will be released on November 24.
