Owners of AMD RX 5700 series cards have another cooling option for their cards now. Whether overclocking or simply seeking a more efficient solution a water block can help with either strategy. Raijintek has released a version of its SAMOS product line for either 5700 or 5700XT models. If curious about the “out of box” experience for these cards then check out our review of both here. Brent even did a follow up review on overclocking both that can be read here. In reading his overclocking review we can see that both cards can benefit from a better cooling solution whether it be for the noise factor or temperature needs. “Designed in Germany, Made in Taiwan”, Raijintek’s new water block for the 5700 series GPU’s could potentially help with both. Well time to meet the SAMOS AD5700 RBW water block.
Compatibility List:
Specifications and Features
- Full-cover water block comprised of nickel-plated copper base to cover GPU, VRM, and Ram.
- Cold plate has 0.5 mm internal fins and 12 mm transparent acrylic cover
- Standard G 1/4″ threaded in/out ports
- 4-pin / 5 volt addressable RGB LED strip
- Aluminum back plate for passive cooling on the back of the card
Still holding onto multi-GPU Crossfire setups? That’s o.k. since they’ve designed it with you in mind as well.
Raijintek was founded in 2013 and produces a wide range of products for the PC enthusiast market. Their product line includes radiators, reservoirs, cooling fans, and liquid all-in-one solutions. For those still using air they even offer solutions for both GPU’s and CPU’s. From their website:
” Our task is to provide products – high compatibility, extreme engineering, remarkable performance, amazing design, necessity of demand and multifunctional usage – for high recommendation everywhere to make up your life. “
Price and availability for Raijintek’s new water block have not been announced yet but a comparable model for the 2080TI runs around $122.66 currently.
