Introducing the EVGA SUPERNOVA GT Series – Redefining Quality, Performance and Value
Refinement In Performance and Design
Upgrade both aesthetics and electronic components with a unique radial design fan grill, compact 150 mm length and width, and 100% Japanese capacitors.
80 PLUS GOLD EFFICIENCY
80 PLUS Gold Certified. Ensures that your power supply is 90% efficient or higher.
750 GT Efficiency
650 GT Efficiency
Fluid Dynamic Bearing
The EVGA SuperNOVA GT uses a long-life 135mm fan with a Fluid Dynamic Bearing (FDB) for silence, reliability, and a longer life expectancy.
Single +12V Output
Provides a stable output for compatibility with the latest hardware.
Fully Modular Design
Choose the cables you need to make cable management simple and clean.
Auto ECO Mode
Fan RPM adapts to the PSU temperature. The fan will shut off in a low temperature/low load environment, resulting in reduced noise.
750 GT
650 GT
Full Protection
OVP Over Voltage Protection
OCP Over Current Protection
OPP Over Power Protection
SCP Short Circuit Protection
UVP Under Voltage Protection
Dual OTP Over Temperature Protection on the Primary and Secondary PCB
